Results 1 to 4 of 4
    Aug 09 2016
    2002 A4 3.0 6 speed manual
    Wyoming, Michigan
    2002 A4 3.0 cam and misfire error codes
    OK so I have some error codes I can;'t seem to figure out where to start looking for the problem. So here I am. My error codes are as follows.
    Fault log report generated by Torque for Android
    Vehicle VIN: Not present
    Vehicle Manufacturer: Unknown
    Vehicle Calibration ID: Not present
    Current Fault Log
    P0050: HO2S Heater Control Circuit (Bank 2 Sensor 1)
    P0160: O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0345: Camshaft Position Sensor "A" Circuit (Bank 2)
    P0011: "A" Camshaft Position - Timing Over-Advanced or System Performance
    (Bank 1)
    Pending Fault Log
    P0300: Random/Multiple Cylinder Misfire Detected
    P0304: Cylinder 4 Misfire Detected
    P0305: Cylinder 5 Misfire Detected
    P0306: Cylinder 6 Misfire Detected
    Historic Fault Log
    ECU reports no historic faults
    Other discovered fault codes
    (possibly pending, current or manufacturer specific)
    ECU reports no other fault codes logged
    End of report.
    Any help would be great.
    Thanks
    2003 A4 1.8T Stock
    2002 A4 3.0 6 speed Manual Stock
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Did you replace the timing belt recently? Based on the codes, I would check the timing on that bank first to potentially clear the misfire and P0011 codes. Look at the wiring for the O2 sensors for the P0160 code.
    Aug 09 2016
    Wyoming, Michigan
    Quote Originally Posted by imnuts View Post
    I didn't do the timing belt YET I'm thinking this might be the problem but I also think it might be the cam sensors. I just don't know where to start with it.
    2003 A4 1.8T Stock
    Aug 09 2016
    Wyoming, Michigan
    OK so I'm going to replace some sensors. What I'm wondering is if all 4 sensors are the same or if they have different part numbers? What is the "A" side? Driver or passenger side? I have a bank 1 and 2 for the "A" side.
    2003 A4 1.8T Stock
