Results 1 to 15 of 15
    Apr 07 2011
    Home of the mighty beaver
    2.8 head question, timing parts.
    Can anyone tell me if the timing chains, adjusters etc can be moved over from 2.7 heads directly to 2.8 heads?
    I have a pair of AHA 2.8 heads that are essentially bare. just valves, springs, retainers, lifters, and cams... All the timing hardware was stripped from them.
    My plan is to just bolt these straight on once they are checked out, (new valvestem seals, etc etc)....
    But ill need to move the timing hardware over from my original (trashed) heads.
    I believe this should be possible, but id like to hear from someone who knows better than me with my middling google skills.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    As far as I know all the timing parts should be usable. They're essentially the same casting as the 2.7T heads, just larger ports.
    You will want to swap at the minimum the exhaust valves from 2.7T heads to the 2.8 heads.
    Also make sure you're using the 2.8 cam caps that came with the heads. Do not swap these!
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by NOTORIOUS VR View Post
    Exhaust valves are actually the same. AFAIK, all 5v (inlducing 1.8t, but maybe not 4.2)heads share the same exhaust valve part number, 058109611E
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jan 29 2009
    Quote Originally Posted by redline380 View Post
    No they're not the same.
    The keeper grooves are lower on the 2.7T valves to increase seat pressure. Either that or it's the intake valves. But there are differences.
    Apr 07 2011
    I have heard conflicting opinions on this one. I have both heads, so I will find out. Some tell me no, not needed to swap them over.. but yes the keeper groove issue is something Im also aware of.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    The 2.8 and the 2.7 use different parts (APB and BEL use the same):
    058109611E - APB exhaust valves
    078109623E - APB exhaust valve springs
    078109021P - APB intake cam cyl. 1-3
    078109021Q - APB intake cam cyl. 4-6
    058109611M - AHA ATQ exhaust valves
    078109623B - AHA ATQ exhaust valve springs
    078109021 - AHA ATQ intake cam cyl. 1-3
    078109021A - AHA ATQ intake cam cyl. 4-6
    Jan 29 2009
    Quote Originally Posted by S4James View Post
    They're different 100%... although it's been a long time since looking at them myself you will need to swap valves, then lap them into the head and replace all valve seals (obviously).
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Someone better tell GAP then because they say the valves are the same
    2000 S4- Working?
    Apr 07 2011
    GAP?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Genuine Audi Parts .com
    2000 S4- Working?
    May 27 2016
    Westchester, NY
    Glad to read these posts. Future build parts gathering
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    2.7 has the keeper grooves cut lower to compress the springs for more seat pressure. Helps keep them closed with higher ex mani psi.
    Many ex brake kits for trucks come with stiffer springs for similar reasons.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Apr 07 2011
    The only question that remains, is how needed is that extra seat pressure?
    People have been getting away without swapping the valves but I have not heard of any issues caused by this, or failures.
    lastly, if one intends to upgrade the springs/retainers... It makes the entire thing moot.
    Jan 29 2009
    With FI you ALWAYS want more seat pressure.
    IF you upgrade springs and retainers (which is what I would do because springs ARE a wear item) you HAVE to get upgraded exhaust valves at the minimum. The stock exhaust valves with upgraded springs have been known to fail and it's cheap insurance.
    So either stick with all OEM 2.7T stuff and just swap everything over, lap them in and be done with it and settle for a lower REV limit, or buy new stuff so you can raise the REV limit and not have to worry about dropping a valve at 8000+ (if you have turbos to support that which you don't) and know that you have good springs in there to avoid valve float.
    Apr 07 2011
    Yes thats right, I remember seeing a set of valves with the ends snapped off.. Long time ago.
