Good afternoon all!
So I have a 2008 S4 avant 6MT, and recently (About 5 times now since I bought the car in April) I will get in and try to start the car, and this is what would happen:
No check engine light or having the dash light up like a christmas tree, only the regular lights that will pop on before you turn the car on, and it is trying to continually start. I do notice on all occasions that the fuel pump is not priming the engine, hence why it is not fully turning over, but it is not consistent. I have done a lot of research and looking and even got my car scanned (which it found 17 faults, will come back to that) and it seems that my issue is the crank position sensor. I have looked into the faults to the best of my ability and they were all thrown 300 miles ago, about the last time it didnt start. But to my understanding the crank position sensor is what will send a signal to all of them (8 being fuel injectors) to be ready to start up and go. Am I on target with this? is there something I am missing? It usually takes about 10 minutes of just trying to start to finally get some fuel through and it starts up, but I would like to find the root cause and get it fixed. If there is something that i missed or any input that people have, would be greatly appreciated; Thanks!
Wall of text from the output of the scan incoming:
Address 01: Engine Labels: 079-910-560-BBK.lbl
Control Module Part Number: 8E2 910 560 F HW: 8E2 907 560
Component and/or Version: LA.2 91OCT JHM G 0010
Software Coding: 0007711
Work Shop Code: WSC 06335 000 00000
VCID: 2A51294985A6196E00-807E
17 Faults Found:
000642 - Fuel Injector #8 (N86)
P0282 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.557 V
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
005157 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000609 - Fuel Injector #1 (N30)
P0261 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000624 - Fuel Injector #4 (N33)
P0270 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000627 - Fuel Injector #5 (N83)
P0273 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
005234 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000615 - Fuel Injector #3 (N32)
P0267 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000630 - Fuel Injector #6 (N84)
P0276 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000612 - Fuel Injector #2 (N31)
P0264 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000633 - Fuel Injector #7 (N85)
P0279 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 195 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114620 km
Time Indication: 0
Freeze Frame:
RPM: 228 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 11.557 V
Readiness: 0000 0000
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Data version: 20160216
www.Ross-Tech.com
Saturday,13,August,2016,17:17:27:22832
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUUL78E78A166004 Mileage: 115080km-71507miles
Address 01: Engine ( ) Labels: 079-910-560-BBK.lbl
Part No SW: 8E2 910 560 F HW: 8E2 907 560
Component: LA.2 91OCT JHM G 0010
Revision: --H03--- Serial number: XXXXXXXXXXXXXX
Coding: 0007711
Shop #: WSC 06335 000 00000
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004901
VCID: 2E592559B94E754EDC-807A
2 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 20
Reset counter: 29
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x6222
Hex Value: 0x0028
Hex Value: 0x0199
Hex Value: 0x0001
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 27
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6222
Hex Value: 0x0024
Hex Value: 0x0198
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DDBE25527C8CE56A5-515C
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 11021
Shop #: WSC 65536
VCID: 3D7B121537289ED655-4B08
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 N HW: 8E0 035 593 N
Component: SDAR SIRIUS 0150
Serial number: AUZ4Z7H0282670
Shop #: WSC 00000 000 00000
VCID: 346D373154625F9EAA-5122
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 M HW: 8E0 959 655 M
Component: Airbag 9.41 H01 4240
Revision: 91H01424 Serial number: 003CS000FNC7
Coding: 0032607
VCID: 41836EE518D0FA3631-8014
Subsystem 1 - Part No: 8E0 910 339 D
Component: BF-Gewichtsens. H03 0080
Subsystem 2 - Serial number: 02D9K
Subsystem 3 - Serial number: 0001.01.0000H0300000000000ÿ† 63
Subsystem 4 - Serial number: 000000ÿ† 6332DRB406F30DB2Xÿ† 63
Subsystem 5 - Serial number: 30DB2Xÿ† 6342DRB407360E9AXÿ† 63
Subsystem 6 - Serial number: 60E9AXÿ† 6352ARB403AF4C97%ÿ† 63
Subsystem 7 - Serial number: F4C97%ÿ† 6362ARB403AFCC798ÿ† 63
Subsystem 8 - Serial number: FCC798ÿ† 63729RB403A970CE ÿ† 63
Subsystem 9 - Serial number: 970CE ÿ† 63829RB403A97134Lÿ
Subsystem 10 - Serial number: 97134Lÿ
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 04042
Shop #: WSC 06335
VCID: 41836EE54BD0FA3631-4B08
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 D HW: 8E0 920 983 D
Component: KOMBI+WFS 4 H10 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0023008
Shop #: WSC 22164 444 69314
VCID: 30653B21A07A63BECE-5122
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023008
VCID: 30653B21A07A63BECE-5140
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: 71E3FE253BF02AB681-4B08
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CP
Component: Komfortgerát T7B 4336
Coding: 12136
Shop #: WSC 06335
VCID: 0103AEE50B503A3671-4B08
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
2 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2953D64580A0127609-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8E0 035 195 AF HW: 8E0 035 195 AF
Component: R Symphony2+ H04 0270
Revision: 00H04000 Serial number: AUZ1Z4H7758215
Coding: 0650002
VCID: 6BDFEC4D49DCC066BB-5140
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 15
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0063022
Shop #: WSC 06435 000 00000
VCID: 2A51294986A6196E00-5122
1 Fault Found:
00456 - Control Module for Access and Start Control (J518)
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Time Indication: 0
Freeze Frame:
(no units): 0.0
Voltage: 12.40 V
(no units): 33.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 R HW: 8P0 862 335 R
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005072205
Coding: 0001677
VCID: 458B7AF50FF8D6160D-5122
End-------------------------(Elapsed Time: 05:59)--------------------------
