Results 1 to 17 of 17
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    How much do stock shocks/springs settle?
    I would have thought a relatively negligible amount. Reason I ask is, like most I don't really dig the stock height/gap. Due to an oddly configured driveway (entry berm to direct water away from the house) I felt like even a slight drop would be risky at best, as non-suv type cars always high center badly coming into our driveway. My wife has a 2016 Q5 3.0, and I couldn't help but feel like the stance looked better on it, even though ground clearance is listed the same at 7.9" Seeing the two parked side by side in the garage today I realized it really did look lower, and measuring proved it to be just over an inch lower than my SQ. Her car only has 3,500 miles, and my SQ has just under 1,000 now. Both bought new, and not modded. That seems like a big difference to attribute to settling, or tolerances. It does give me hope that maybe I can do a slight drop on the car though (though I have bottomed hers out coming out of the driveway too straight. Thoughts?
    Jun 25 2016
    Calabasas, CA
    Maybe I'll try this a different way. Anyone with stock suspension have their FTG measurements handy? Curious which of my cars is "off".
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Quote Originally Posted by buggravy View Post
    I'm having new springs installed tomorrow. I'll take some measurements before I have the work done.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Jun 12 2015
    CA
    My FTG is 29 in the front, and 29.6 in the back. That value hasn't changed in the month since install.
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    I wouldn't expect that big a difference between the cars, certainly not just because of settling. For reference, my SQ5 was almost exactly 32.5" FTG both front and rear after a couple thousand miles. See pictures below.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Jun 25 2016
    Calabasas, CA
    Quote Originally Posted by riceboy22 View Post
    Thanks, that helps. 32.5" is pretty much exactly where I am as well. Wife's Q5 is at 31.5". Something to do with the adaptive damping, I wonder? Anyway, this at least gives me hope that I can pull off a Euro spec, or similar drop.
    Jan 01 2016
    Tampa Bay
    I just measured mine. Stock height for me is 32" FTG front and rear. Mine is a 2015
    SQ5 with about 18k miles. I have the standard non-adaptive suspension.
    If you have the stock adaptive damping it can be different depending on what setting you are using.
    S4 Build Thread
    Registered User Four Rings
    Jun 25 2016
    DMV
    OP,
    Post pictures
    Jun 25 2016
    Calabasas, CA
    Quote Originally Posted by agautohaus View Post
    OP,
    Post pictures
    Will do. Wife already flew the coupe for work, but will snap a couple tonight.
    Jul 10 2014
    Start it up and see if it's raises... I thought ADS lowers the car a little in dynamic... Am I wrong?
    Senior Member Three Rings Qumag's Avatar
    Dec 11 2014
    18'GLC63 AMG, 17' VW Golf Alltrack
    Darien, IL
    Quote Originally Posted by Silverarrow240 View Post
    It only adj the suspension dampers, no ride height adj.
    Jun 25 2016
    Calabasas, CA
    Will check that tonight, though I know she always keeps it in auto mode. That said, I thought that the SQ5 suspension was essentially the Q5 in permanent dynamic mode. Maybe the reverse is true, and in the softer setting the static weight of the car compresses the shock more when parked? A full inch seems like a lot though.
    Established Member Two Rings poncho@home's Avatar
    Oct 22 2014
    17 Mustang GT, 04 BMW 330Cic ,11 Subaru Legacy
    Do both cars have the same size wheels/tires? If her car has a smaller diameter tire, than her Fender to Ground measurement would be less than yours (lower to the ground). Measure the how tall the your actual tires are, measure the gap between the fenders and the top of the tires, that will give you a better idea of why hers has less ground clearance.
    Springs would not "settle" that amount in such a short period, and springs are part of the factor in ground clearance, overall tire diameter as well.
    2013 Audi Q5 3.0T Quattro S-line, Nav/MMI, B&O, Pano
    2017 Ford Mustang GT 6 spd manual
    2004 BMW 330Cic 6 spd manual
    2011 Subaru Legacy 6 spd manual
    Jan 08 2016
    Los Angeles, California
    Quote Originally Posted by Qumag View Post
    Was does that even mean? Doesn't dampening something mean to reduce it, i.e. make it slightly tighter/lower?
    Dec 11 2014
    Darien, IL
    Quote Originally Posted by Pittdawg View Post
    Damper" is a term that describes the primary function of a shock or strut. Both are intended to control spring oscillation. They do this by damping the spring's natural tendency to oscillate by using hydraulic fluid such as struts or shocks. The ADS simply adjust the valve inside of the struts/shocks to control the compression and rebound that hence changes the suspension ride NOT height..
    Jan 08 2016
    I think I understand now; basically the ADS tightens up the shocks, reducing the amount of flex in the springs, ultimately providing crisper, more responsive steering but the ride height remains unaffected. Is that the general nature of it?
    Jun 25 2016
    Calabasas, CA
    Quote Originally Posted by poncho@home View Post
    Different size wheels (20 for her, 21 for me), but they're OEM and diameter for both tires is 29". Gap is smaller on her Q. Forgot pics tonight, but will try to do tomorrow.
