CTS B7 A4 Product Thread!
Questions? Send me a PM or send an email to [email protected] if there are any questions!
ctsturbo.com is our website, We have a massive online store to take care of all your shopping needs.
B7 A4 Front Mount Intercooler Kit $849.99
Click here for ordering
The new CTS Turbo B7 A4 FMIC kit will enhance the performance and power of your vehicle substantially by maintaining lower charged air temperatures even under the most extreme abuse. Boasting a high density bar and plate intercooler core (rated for 600HP) the CTS FMIC kit is ideal for modified B7 A4's with K03, K04 or even big turbo applications. Smooth transitions in our hand crafted intercooler piping ensure quick boost response and optimal flow. Fitting an intercooler this size is no easy task, but our design requires absolutely no trimming to the bumper. Trimming to the bumper reinforcement is required for installation.
Product details:
- High density bar and plate intercooler core
- Core dimensions 20" x 11" x 3"
- 2.5" hand fabricated stainless steel piping
- Stainless steel T-bolt clamps and 4 ply silicon connectors
- Bead rolled pipe ends to prevent hoses popping off
B7 A4 2.0 BorgWarner K04 Turbo Upgrade Kit $2299.99
The heart of the CTS Turbo B7 A4 2.0T turbo upgrade kit is the Borg Warner K04-0064 turbocharger. This turbocharger is commonly used in OEM applications such as the Audi S3 available in Europe. The highlight of this Borg Warner turbocharger in our kit is the 'forged mill' compressor wheel, which brings numerous benefits to the enthusiast. The technology used in the production of these turbos provides us with a variety of benefits, reduced compressor wheel weight (faster spool), increased strength, and greater surface area of the compressor wheel. Because of the 'forged mill' technology Borg Warner can increase the effective surface area of the compressor wheel, which results in greater air flow than conventional cast compressor wheels.
In addition to the Borg Warner K04-0064 the CTS Turbo B7 A4 2.0T turbo upgrade kit uses a set of custom silicon hoses to relocate the factory diverter valve. Our diverter valve relocation uses the same principles as the OEM Audi S3, Audi TTS and Golf R. In addition to the diverter valve relocation our kit includes a new diverter valve housing to relocate the diverter valve, associated OEM gaskets, nuts, studs and hardware and test pipe to connect to your factory downpipe. This kit is by far the best 'bang for the buck' modification available for B7 enthustiasts with the 2.0T engine.
Power with Unitronic Stage 2+ tune: 335hp/335lb-ft tq
UNITRONIC STAGE 2+ : 335HP / 335LB-TQ
Kit must be used with test-pipe that is included.
Additional parts required:
Autotech HPFP upgrade
Audi S3 fuel injectors
K04-specific software
B7 A4 Silicone Intercooler Hose kit $179.99
CTS Turbo now offers a full silicone intercooler hose set for the B7 Audi A4 2.0T FSI. The hoses that come stock with your A4 age and deteriorate over time. This will lead to inevitable boost leaks leading to loss of power and increased wear on the turbo. CTS Turbos hoses are far more durable and are guaranteed to not crack. Our super rigid construction eliminates hose expansion and deformation under high boost pressure.
A recommended addition to this kit is our B7 A4 Turbo Inlet Hose.
B7 A4 Silicone Turbo Inlet Hose $69.99
Turning up the boost in your car increases wear on your stock rubber turbo inlet hose. Eliminate cracking, stretching and deformation with this CTS Turbo B7 A4 Silicone Turbo Inlet Hose. Increased rigidity and higher flow mean less restriction and more power.
This is a recommended addition to our B7 A4 Intercooler Hose Set.
B7 A4 Test Pipe/HFC $149.99
The CTS B7 A4 2.0T test pipe is the premier test pipe for your B7 Audi A4 2.0T. Our test pipe is designed to seamlessly fit in place of your restrictive stock catalytic converter, which is situated immediately after the turbocharger. Our test pipe features 3" stainless steel piping, smooth mandrel bends, two 02 sensor bungs with an option for a third. Substantial power gains, improved exhaust flow and a more throaty sound are the main benefits from installing our test pipe. Upon inspection you will notice smooth mandrel bent piping with seamless transitions from the turbocharger to the exhaust system. In addition to being one of the best bang for the buck performance upgrades for A4 owners our test pipe is also very attractive piece. Each 3" test pipe is mandrel bent, hand tig welded and comes with the standard CTS swag (lanyard and plate frame). Do you need an additional 02 bung for data logging? Well that's no problem! Tig welding additional 02 bungs can be done for an additional charge.
Product Details:
T304 stainless steel construction
Mandrel bent stainless steel
Fully tig welded design
Optional third 02 bung
Install hardware included
Throaty sound
Great power upgrade
Autotech FSI High Pressure Fuel Pump Upgrade Kit $359.99 shipped
High Pressure Fuel Pump Upgrade Kit 2.0T FSI
Autotech is the premier manufacturer of fuel pump upgrades for the FSI engine because our kit offers the highest quality, solid engineering, and great value. Our HPFP Kit can achieve flow rates 50% higher than the original pump, essentially removing pump limitations from the equation, even on high-end turbo upgrades. Our HPFP kit continues to be the benchmark that imitators strive to reach. However, Autotech’s HPFP Kit is not easily duplicated. There are many reasons why Autotech’s Kit is superior. Here are a few:
~Each piston (9.8mm) and cylinder in Autotech HPFP kit undergo high-precision grinding processes many times during their manufacture, ensuring that the most precise tolerances are maintained through the final step. Not the cheapest way to make them, but the best way.
~Each piston and cylinder are match-ground and serialized to ensure absolute precision and the utmost longevity.
~Autotech was the first to incorporate plasma DLC coating on HPFP components to reduce friction losses and increase performance. Others have tried to follow by adding a coating to their parts. However, the DLC process alone is not enough – it is not a cure for substandard precision – the parts must be engineered specifically for the process to take full advantage: Autotech’s are. The success we have in the field can attest to that.
~HPFP-specific mapping is now commonly available from tuners worldwide.
FSI RS4 Injector Set of 4 (079 906 036D) $349.99 shipped
CTS is pleased to offer this set of (4) OEM (079 906 036 D) B7 RS4 fuel injectors which are primarily used when upgrading fuel systems for VW and Audi FSI motors. These injectors are a great and inexpensive solution for all your 2.0T FSI big turbo fueling needs. Tested to over 500whp, these injectors are commonly used with Unitronic, Eurodyne, and Revo big turbo software.
S3 Fuel Injector Set of 4 06F 906 036 F 06F998036F $499.99
These injectors flow 13% more the factory A3/MKV 2.0T FSI injectors. They bolt on with no modding and are the perfect upgrade to anyone going to a bigger turbo.
Complete your FSI K04 car with the help of the S3 injectors, to prevent the damages of running lean. If you're making your own K04 turbo kit for MK5 GTI, GLI, or B7 A4 then you'll need these S3 fuel injectors. Also requried is an upgraded high pressure fuel pump and upgraded software.
B7 A4 2.0T Catback $1,049.99
CTS Turbo has been dedicated to manufacturing performance parts for enthusiasts by enthusiasts since its inception. Our continued development of the B7 A4 platform is not limitted to FMIC kits or Turbo kits, our all new catback exhaust system is evidence of that. The CTS Turbo B7 A4 catback exhaust system is hand tig welded using the finest T304 stainless steel.
Each CTS B7 A4 catback is 100% tig welded, constructed using T304 Seamless Stainless Steel, and includes installation hardware and stainless steel clamps. Lesser products can be had without stainless steel construction, or with seamed stainless steel, which can crack and decay over time. The CTS Turbo B7 A4 increases turbo spool up, and peak power.
The downpipe is constructed using 2.5in T304 Stainless steel. It will bolt up directly to the OEM catalytic converter, aftermarket high flow cats or our test pipe.
Product Details:
- True Stainless steel catback exhaust
- Aggressive sound under hard driving, but subtle when cruising
- Water jet cut flanges
- CNC mandrel bent stainless steel piping
- Polished stainless steel exhaust tubing
- 3" stainless steel exhaust tips
- Fits manual transmission Quattro cars only (will not fit Automatic or FWD cars)
CTS TURBO 2.0T BOV (BLOW OFF VALVE) KIT (EA113, EA888.1) $269.99
CTS Turbo is proud to release our 2.0T Atmospheric BOV KIT for EA888.1 equipped vehicles. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) is made of billet construction and completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars.
Fitment:
Audi A3 8P (EA113 & EA888.1)
MKII Audi TT (EA113 & EA888.1)
MK5 GTI (EA113 & EA888.1)
MK5 Jetta (EA113 & EA888.1)
MK6 GTI (EA888.1)
MK6 Jetta (EA888.1)
EOS (EA113 & EA888.1)
Tiguan (EA888.1)
B6 Passat (EA113 & EA888.1)
Passat CC (EA888.1)
Beetle (EA888.1)
Audi S3 8P (EA888.1)
Golf R (EA888.1)
B8 Audi A4 (EA888.1)
B8 Audi A4 (EA888.3)
B7 Audi A4 (EA113)
Product Features:
T6061 billet aluminum construction
Black anodized stealth finish
Fully compatible with OE electronics
Fully serviceable piston design
No additional wiring required
Substantial reliability improvement over OE
Compact design fits into tight spots easily
CTS TURBO 2.0T DIVERTER VALVE KIT (EA113, EA888.1) $269.99
CTS Turbo is proud to release our 2.0T DV (DIVERTER VALVE) KIT for EA113 and EA888.1 equipped vehicles. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT is made of T6061 billet construction and is completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars.
Fitment:
MK6 GTI (EA888.1)
MK6 Jetta (EA888.1)
Tiguan (EA888.1)
Passat CC (EA888.1)
Beetle (EA888.1)
Golf R (EA888.1)
B7 Audi A4 (EA113)
Product Features:
CTS B7 A4 FSI Crank Pulley Kit $179.99
The CTS Turbo crank pulley is lightened to reduce parasitic drag on the engine. This results in faster revving and more horsepower. Included in the kit is the lightened crank pulley, 6 replacement bolts and a shorter belt. The pulley is made from T6 6061 aircraft grade aluminum and hard anodized to reduce wear. Gains of 5-7 horsepower can be expected.
- - - Updated - - -
Be sure to check out our website at www.ctsturbo.com as our Summer Sale is running now until Aug. 31/16
