Results 1 to 6 of 6
    Veteran Member Three Rings chad99's Avatar
    Apr 21 2012
    Fremont, CA
    Force zero boost
    So I am planning on shipping my car in the future and would like to find a way to either safely force and keep the car in limp mode or prevent the turbo from building any boost to prevent any parking lot cowboy antics.
    I was thinking of disconnecting the n249 from ECU and connecting a switched 12V and ground to the N249, forcing the DV to always see vacuum from the reservoir. My plan is to wire it up with another N249 connector so I can still drive the car where I need to then just pullover and swap plugs right before I enter the parking lot.
    Any thoughts on this? Or a better/ easier way to prevent boost or force limp than can be easily done quickly on the side of the road with a engine up to temp?
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    The only way i think that it will happen is if you leave the wastegate open. Whats your setup?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Do you mean N75, that controls the wastegate?
    You could put a small relay in-line with one of the N75 wires, and wire an in-dash switch to that relay.
    This would force an open-circuit at the N75 whenever the switch is in the OFF position... limiting boost to wastegate pressure (4-5psi for a K03)
    2 side effects:
    -fault code & possible CEL for N75. You could strategically wire in a resistor to prevent this fault code.
    -fault code & possible CEL for underboost
    More simple option is unplugging the N75 electrical connector... takes about 3 seconds. This has the same consequences as above.
    Pretty much unless you have a proper tune, you will get a fault code for underboost.
    2001 Corvette (C5) Z06
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    As MetalMan pointed out, simply unplug the harness to the N75. Permanent limp mode.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Another thought, is to physically limit the throttle pedal - I'm not familiar with the pedal, but there's got to be an easy enough way to limit how far it can travel.
    Apr 21 2012
    Fremont, CA
    Thanks guys I'll just do the n75 it's easy enough
