    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Stoptech ST-40 brakes - No Longer Available
    Removed from a b6 S4.
    ST-40 (4 piston) calipers
    Rings are included, 355 mm rotors can be had from Amazon for 260 shipped each of you are a prime member.
    Includes pads (unknown brand) and SS lines
    Two screws on one the the rings will need to be removed, I didn't have an easy out that would fit them, threads have not been touched.
    List Date: 8/17/2016
    For more info, click here to view the original listing: Stoptech ST-40 brakes
    This item is no longer available.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Will you sell the rings only? And would you happen to have the ring part numbers? Thanks in advance.
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by xalents23 View Post
    I think I'd have a better chance of selling the kit. Not sure on the part numbers
    Established Member Two Rings jdorpaudi's Avatar
    Apr 07 2009
    2002 Audi S6, 2008 F350 Lariat, 2016 F150 Lariat
    Winnipeg, Manitoba
    Does anybody know if these calipers will fit a 332 kit? If so I'd take the calipers and xalents can take the rings.
    Do you have a part number for the calipers?
    Apr 07 2009
    Winnipeg, Manitoba
    I'll definitely take the calipers. Pm sent
