Just picked up a 2003 AR Cobalt blue with the 2.7t and TIP. Motor is pouring oil some where out the back of the motor. When I pour oil into the filler port, it literally pours out the back without the engine running.
It has good compression on 1, 2, 4 and 5 cylinder so figure it is toast.
I can either replace the BEL 2.7t with another 2.7t or I have the option to buy a 2004 A6 with a AWN 4.2 V8 ((timing belt) and a bad TIP.
I know the A6's with the 4.2 were "wide body" cars. I also know that some AR's came with the timing belt V8 but more came with the timing chain V8.
My question is, does the V8 require a slightly larger engine bay in the AR which came with a 2.7t? In other words, will the V8 fit in a AR that didn't come with a V8 originally?. You can see the difference in the A6 bodies on the outside, but I cannot see a difference in the AR's.
