    Established Member Two Rings goblues38's Avatar
    Aug 14 2016
    STL
    SQ5? - Is there a list of top speeds in each gear some place?
    Just want to know the limits for downshifting with the paddles.
    Jun 12 2015
    CA
    There are websites where you can calculate these numbers if you know the gear ratios and tire diameter of your vehicle.
    Aug 14 2016
    STL
    here is what I was able to pull together for top speed at 6500 rpm for each gear on 21 inch wheels. Obviously, the #'s for 6-7-8 are mechanical theoreticals.
    6500
    1st .....4.714...... 37
    2nd .....3.143..... 56
    3rd .....2.106..... 83
    4th .....1.667..... 105
    5th .....1.285..... 136
    6th .....1.000..... 175
    7th .....0.839..... 209
    8th .....0.667..... 263
    final drive 3.204
    21 inch tire 29.03
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    I believe that is the Q5 3.0T final drive ratio. It's believed to have been mis-published at some point (on Audi's website I think), but general consensus is that the SQ5 has always had the 3.076 final drive. And obviously 354hp, even 450hp with a tune, isn't going to overcome the wind resistance and rolling friction at speeds anywhere close to 200mph, but it would be cool to know exactly what the platform is capable of...
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Oct 26 2015
    Norman/OK
    It wont matter, the ECM will not allow you to downshift with the paddles into a over-rev condition. It has fail-safe built into it.
