Results 1 to 7 of 7
    Established Member Two Rings Wyd's Avatar
    Jun 29 2016
    WA
    Engine stand to do chains
    I've seen it in a picture before so I'm believing it's possible but how would I mount the front of my 4.2 to an engine stand so I could do my chains. Would rather not keep the motor on the crane. But have sort of though about making a cradle.
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    i kept my engine on the crane but had it also resting on a tire to keep it from spinning around. not the best but it worked for.
    i've also researched how to properly secure it a engine stand and it seemed most members on this site and others deemed it unsafe for the the engine block. there are mounting holes on the crank pulley side but you can only secure the top half i believe.
    even the bentley manual shows a specific VAG engine stand that uses the engine mounts to secure it.
    hope this helps
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    I've seen it done somewhere , but I would not trust the threaded holes in front of the block(especially the tensionner and Idler bolts holes) for supporting the engine, as they are pretty small
    I didn't really look into doing that when doing my timing as I built a wooden "cradle" to support the engine on the workbench
    Jun 29 2016
    WA
    maybe ill rig something for a cradle that bolts to the mounts,
    thanks for the input!
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    I built one from 2x4s
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Sep 09 2011
    2011 Chevy Duramax, 1999 Mazda Miata
    Chardon, OH
    I built this one using 1" square tubing
    RIP 2004 S4 built by Gellner Engineering Racing Engines
    Jul 15 2015
    Rochester NY
    I also built mine with 2x4s, and used the shop crane to turn it as necessary. Just finished reinstalling pistons and rested it on the stand, lifting it to rotate the crank as necessary (using a couple of bolts in the flywheel holes and the handle of my wire brush to turn it - I only use the professional approach ; )
