Results 1 to 9 of 9
    Aug 16 2016
    Buffalo, NY
    Tuning a High-Mileage A4
    Hi. I have a 2005.5 Audi A4 2.0T (auto) and I want to get an APR tune for it. It's quick, but I would like it to make more power. My only hesitation is that it has 176k miles. The previous owner never drove it hard and the timing belt was replaced two months ago. I can drive it pretty hard and the car responds exactly as it is supposed to with no concerning behavior or noises.
    Does anyone have any experience tuning an A4 with such high miles? What kinds of things should I look for before I do this?
    Thanks.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I see no downside in tuning a higher mileage car. My car currently has roughly 200,000 miles on it and I am running a JH M Stege 2, 93 octane tune. It is considered to be one of the most aggressive is not the most aggressive off-the-shelf tune, and my car runs fine. Where you need to do is make sure all of the maintenance items are done. If all of the maintenance items are done and your car is not throwing any codes thus runs great, tune away.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Make sure you're up on your maintenance and I see relatively low risk. Of course, there is always some risk with tuning
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I went Uni Stage 1+ at 175k when I bought the car, make sure to change the cam follower and oil level is good before driving it hard on the tune.
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Apr 24 2016
    California
    Quote Originally Posted by james12lucy View Post
    When did you replace your turbo?
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Jun 17 2013
    jersey city nj
    Ive got 230,000 miles on my car and the out of it daily. All my mods are in my signature. I did all the mods @ 161,000 miles.
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by RakkCity View Post
    Never. Still running factory K03. 93 octane, stage 2 operates with the K03.
    Apr 24 2016
    California
    I assumed you'd replaced it at some point with another OEM. Damn, 200k on a factory turbo with a stage 2 tune? That gives me lots of hope. I was planning on buying a backup unit for my 140k car for fear a tune would be too much for the factory snail.
    Jul 04 2015
    Toronto Ontario
    My car has had a tune since about 175 miles. Factory turbo doesn't burn oil. It may have been replaced by the previous owner, but I have every receipt for all work done (including oil changes) and there isn't nothing for the turbo. Having said that, he was meticulous, and I wrench as a form of stress relief.
