Results 1 to 4 of 4
Thread: RS5 track day
    Active Member Two Rings MacFiend's Avatar
    Feb 26 2013
    2015 SQ5
    San Diego, CA
    RS5 track day
    Getting ready to take the RS to the track for the first time. New tires and brake fluid and car is running great.
    That being said, any suggestions or comments on what to expect from this car on the track?
    Other car bits:
    Bilstien Ride Control coil overs
    Alukruez subframe
    CR15 strut tower brace
    Michelin PSS
    Sent from my iPad using Audizine mobile app
    Veteran Member Three Rings xquizit's Avatar
    Jul 25 2007
    '18 Cadillac Escalade, '19 Mercedes G550, 2018 Audi R8 RWS
    Jacksonville, FL
    There was a previous thread here about the brakes/rotors. Check it out http://www.audizine.com/forum/showth...-for-track-use
    Car: Ibis White 2014 RS5 4.2 FSI V8
    Mods: Accuair | Brixton Forged M51 20x10.5 | Ecodes | Eventuri Intake | Eventuri Slam Panel | Balance-it Rear Valence |
    Feb 26 2013
    2015 SQ5
    San Diego, CA
    Good link with lots of good info on brakes. Thanks.
    Senior Member Two Rings jwr9152's Avatar
    Apr 08 2015
    Pensacola, Florida
    Personally not a big fan of super sports for the track. I'm kind of partial to sport cup 2's. Not sure what pads you are running, but I would look at a higher temperature compound then oem. Other then that it should do really good on the track. You'll also want to keep track of your tire pressures. I usually run around 35 front and 32 rear.
    2011 S5 6 spd 4.2 V8 with APR stage 3 supercharger, APR tune, B&B exhaust, Bilstein PSS10 B16, 034 strut mounts, SPC adjustable control arms, USS sway bars and end links, JHM lightweight flywheel and clutch, Meisterwerk short shifter, 034 transmission mount, Stoptech BBK, carbotech xp12, alu kreuz, 034 intake, apikol differential mount, AWE S-flo filter, cr-15 strut brace, Advanti Hybris 19X9.5, Michelin Sport Cup 2 275/35/19. USP RS5 grill. 034 Motor Mounts
