Results 1 to 14 of 14
Thread: 3800 rpm limit?
    Senior Member Two Rings Hy Octane's Avatar
    Jan 25 2013
    3800 rpm limit?
    Funny thing I just noticed.. after 3 1/2 years.. In Park or neutral while stationary, if you blip the throttle it will not allow the 6cyl to go past 3800 rpm?.. S'up wit dat?
    2013 S5 Coupe S-Tronic| Monsoon Grey | Premium Plus | Black Nappa Interior | MMI Nav Plus Pkg | Sports Diff | B&O | Advanced Key | 19" Wheels | H&R OE Springs | H&R Wheel Spacers 15mmF/ 20mmR |
    Senior Member Three Rings burg3ngold's Avatar
    Apr 13 2016
    Washington DC Area
    Probably not a good idea to Rev your motor that high in park or neutral
    Sent from my ONE A2005 using Tapatalk
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Quote Originally Posted by Hy Octane View Post
    I noticed that the first day I got my car. Maybe that's engine protection from overheating due to stationary high rev-ing. If you are rolling you are free to put in neutral and go all the way to redline.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Senior Member Two Rings soulvxr6's Avatar
    Aug 30 2010
    yamaha r6, mountain bikes
    lawrence ma
    Pretty sure it's launch control
    Leo
    2013- s5m /Roc euro intake /Awe track w. Non res dp /Rs5 style black grill / H&R Sport Springs /034 inserts/GIAC stg 1/ Vff-103
    2002- a4 1.8tqm
    Jul 05 2015
    West TX
    rev limiter.
    tune will eliminate that, and you can rev to redline at park or N all you want
    what a time to be alive
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Rev limiter (fuel cut-off point) due to engine protection
    Only way to eliminate that is the tune (APR, 034, GIAC, etc.)
    Why would you want to rev that high in neutral?
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by burg3ngold View Post
    Why?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    I wish someone would tell the Ferrari and Lamborghini drivers of Dubai this fact, there's not a week goes by without some inconsiderate prick holding his supercar on the rev limiter for 3 minutes outside our apartment at 2am. These people obviously don't wake up at 5am to go to work.
    rant over.
    Oct 08 2015
    Quote Originally Posted by JamesRS5 View Post
    rant over.
    Just saw a video of an Aventador got on fire by reving in neutral at a red light.
    Current: '18 M3 ZCP
    Jan 07 2011
    2013 C300 4Matic
    I rev my car while parked all the time to 8k rpm
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Junior Member Two Rings
    Apr 26 2015
    New Smyrna Beach FL
    That's awesome
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    If you turn off traction control you can rev all you want.
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Senior Member Three Rings BuffDavid's Avatar
    Aug 15 2016
    2015 Jeep Grand Cherokee Limited 2012 Hyundai Genesis Sedan 5.0
    Jacksonville, Florida
    I recently bought my B8.5 S5 ,and when I was doing the test drive, I always tests it's limits. I immediately notices the 4K RPM limiter on Park/Neutral. It's for "protection" as everyone has said,along with using launch control. Regular launch control has a safety applied to the % of Torque applied when launched, and you can see how the car laggs for half a second after you launch.
    This was all removed when I got the car APR Tuned to Stage 2 ECU and TCU. Not only can you now Rev to Redline at a Stop (to show off or whatever,I personally don't do it since I don't have an aftermarket exhaust yet), but now when using launch control...Torque applied is insanely high where you can even get a little wheel spin if you launch at 6K RPM (There are 3 Levels of Launch after tuned...you just hold the accelerator down and the RPMs pause at 3 different RPMs until you launch).
    They're too many limits and restrictions put on the car,simply tune it at least to stage 1 and you'll really appreciate the difference.
    Veteran Member Three Rings TTRStud's Avatar
    Jul 12 2013
    Jacksonville, FL
    No need for a tune to disable it, at least not with the manual transmission cars. Simply press and hold down the electronic stability control button until it is FULLY disabled. If only pressed quickly once, and not held for long enough, it only partially disables the nannies and it will not work. Anyhow, once all nannies are fully disabled, the car will rev past 3800 when stopped. That said, avoid over-revving the engine unnecessarily, specially while stopped and not enough air running through the front end/engine cooling system.
    '10 Meteor Gray Metallic S5 Prestige Loaded 6MT - AWE Track - PCed OEM Rotors
