Results 1 to 28 of 28
    Nov 02 2015
    Orlando, FL
    Another Spark Plug Thread...
    I did a search and there is all kinds of conflicting info on this site, haha
    I have a 2014 Audi S4 (APR Stage II). I'm at 28K miles. Changing out the spark plugs ahead of maintenance schedule and coil packs (its cheap maintenance).
    I ordered the ignition service kit off ECS tuning which included the plugs and the coil packs. The plugs are Bosch 101905631G
    Searching this site various posts say those plugs are supposed to be for the pre-facelift... mine is post-facelift (which is apparently supposed to be NGKs)... its the same engine for pre and post, does this actually make any difference? Am I good to use these plugs?
    If so, I want to confirm the gap I should set the plugs to... .032? They appear to be pre-gapped at around .28
    And then finally, torque should be 22 ft/lbs? 22ft/lbs + 90 degrees? or 23 ft/lbs? haha
    Thanks,
    Chris
    2018 Audi RS5 Coupe, 034 Motorsport ECU and TCU tune, 034 Motorsport Front Strut Brace, 034 Motorsport Transmission Mount Insert, Kohlefaser Luft-Technik Carbon Intake System, MercRacing Multi-Pass Dual-Core Heat Exchanger, Pierburg CWA100 Water Pump, Bull-X Resonator Delete Pipes, ORT Motorsport HPFP, Maxton V2 Front Splitter, Savini SV-F5 20x10 Wheels, Michelin Pilot Sport 4s 285/30/20 Tires, H&R OE Sport Springs (yet to be installed)
    Nov 02 2015
    Orlando, FL
    I called the dealership and they said it has to be the NGKs and not the Boshe... looks like I'll be sending these plugs back to ECS.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    just get the ngks off amazon
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Nov 02 2015
    Orlando, FL
    Quote Originally Posted by CELison View Post
    That's what I'm doing now, thanks!
    Jul 26 2014
    Based on the Audit parts catalogue both 101905631G (Bosch) and 101905611G (NGK) were applicable before 10.01.2011, only NGK part number applies afterwards.
    So basically Bosch and NGK are interchangeable, were both officially supplied as OEM parts at some point in time.
    2011 S5 Sportback
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    NGKs are cheaper at rock auto
    [B]Current: Shopping now....
    Senior Member Two Rings robertstitt's Avatar
    Jul 24 2016
    Richmond Hill
    Anyone use Denso's Iridiums? I've seen some on Amazon that say they fit 2013 S4
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    My understanding is that genuine Audi for B8s was Bosch but both B8s and B8.5s are now both NGK
    Gapping is still confusing me though... Straight NGK branded from ECS (not genuine VAG, albeit identical) came gapped for me at 0.030 while the NGK website says that they should be 0.032 for the 3.0 TFSI. Now I've heard that the VAG branded versions come gapped to specification but need to be checked. And I've been told conflicting numbers that genuine VAG is 0.032 and also 0.028. Although there isn't really much difference there
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    This is what I'm using on my S4 with no issues, gapped at .028.
    NGK 94460 PFR8S8EG Laser Platinum Plug
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Established Member Two Rings khahn's Avatar
    Jun 12 2016
    Decatur, tx
    Quote Originally Posted by RWD2quattro View Post
    Just did the same .
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    Mine is b8.5 on KI184mm + 57mm CTS using NGK iridium BKR9EIX 2669 gap 0.28 bought on amazon $42 for 6pc
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Do note to check the gap when brand new...I have 4 different reading on 6pc new plugs...
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    May 12 2016
    So it looks like most people gap to .028" for stage 2 BUT is that the OEM specification or is that just what the tuners have recommended? Taking my car back to stock for diagnosis and need OEM specs
    Dec 29 2011
    The Bay
    OEM is .032, I gapped to .028 from my own experience with misfires and higher boost. I don't think there's a tuner recommendation, guys on this board are from .025/6 (dual pulley/E85) to .028 stage 2.
    That's something that you'll have to play with and see what works for your car/tune.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    IIRC, pre-FL cars were .028" on the Bosch, but Post-FL on the NGK's was .032". I could be wrong though...
    Chris, the OEM NGK's are more than sufficient with the OEM gap. When I pulled my OEM plugs, they were actually between .026"-.030" (ran them on regular stage 2). I would gap them to .028" personally if I was stage II again, as I felt the .032" was slightly "tame" in feeling (could be placebo though as I didn't get to log) up top.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Is it necessary to change the coil packs with the plugs?
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by Dr GP View Post
    nope, not unless coils are not firing correctly.
    Senior Member Three Rings Vendetta44's Avatar
    Feb 27 2014
    2016 Jeep Grand Cherokee. 5.7L Hemi
    Sarasota, Flo
    Just replace plugs with NGK 9's and now cars not boosting as much as it was on the oem plugs. Im APR stage 2 duel pulley. Gapped them at .26
    Nov 02 2015
    Orlando, FL
    Quote Originally Posted by Vendetta44 View Post
    My car did NOT like the 9's (lots of carbon build up on them after only a few weeks). Log for misfires and see what you get. I switched back to the 8's and all good.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    other people have posted they had NGK's 9's make for lots of misfires. I just did the 8's and .30 gap, and my stage 1 car is pulling hard and smooth.
    Feb 27 2014
    Sarasota, Flo
    Alright thanks guys 👍 back to oem I guess
    Sent from my SM-G935V using Tapatalk
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Sounds like I should go back to the 8's. Installed the NGK 9's when I went DP 1200 miles ago, seems to run good but haven't logged or anything
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    Quote Originally Posted by ModItNow View Post
    Go back to the 8s. We live about 2.5 hours apart and climate is fairly similar this time of the year.
    I had the 9s in mine gapped at .026, misfires and pulling throttle %.
    Back to the 8s (at .026) and the car pops again.
    Now, when it gets 90+ (which doesn't happen often in Napa), 9s might be beneficial. Right now? Not so much.
    -DL
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Jul 21 2004
    South Florida
    FWIW, I run the stockers all times of the year in S FL on a 3.17 PR and no issues with them looking overheated.
    Mike
    2018 Audi S5
    Gone-
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by Lensch09 View Post
    -DL
    Hey thanks for the advise, I'm going to switch back to be safe.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by Loe View Post
    My B8 had NGK's gapped to .032 from the factory, lol
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Aug 12 2013
    Lexington KY
    So I just did my 55k maintenance and used NGK's from Europaparts. I didn't check the gaps on the plugs as I had heard they come pre-gapped. Do I need to pull the plugs again and check? Everything seems to be running fine. Actually, running much better since the plugs/oil change.
    Thoughts?
    Jul 21 2004
    South Florida
    It is good to check gaps but maybe it will set you at ease that my b8.5 spark plugs when I pulled them were all gapped at around .028 and all of the ones that I purchased as replacements were all gapped at around .028.
    2018 Audi S5
    Gone-
    Senior Member Three Rings protogeoff's Avatar
    Nov 12 2016
    Port Moody
    I just replaced the original set on the car. Oddly the factory gaps that I pulled out were all over the place. Between 0.025 and 0.032 according to my feeler gauges.
    V1Rotate
