    Deactivated Three Rings
    Oct 13 2010
    Montreal
    Unitronic Performance Exhaust Upgrades for 8V Audi A3
    Unitronic is pleased to present its Performance Exhaust Upgrades for the 8V Audi® A3®. Unitronic's Exhaust Systems are a direct bolt-on, providing hardware support complementing its Performance Software to achieve maximum performance without sacrifice.
    Unitronic's philosophy in designing Performance Hardware starts by first analyzing the factory component(s) in various street and track environments to determine overall performance and likely limitations beyond certain power levels. Through analysis of the data collected, along with engine calibration and engineering principles applied, goals were set forth; optimization of exhaust gas flow and limiting backpressure on the turbine were top priority from a functional, performance oriented standpoint. In addition to these, all of Unitronic Performance Hardware products must ensure precise OEM-like fitment and top tier component quality. All of this must be met without sacrifice, while also ensuring a competitive performance to cost ratio for our end-users.
    All of Unitronic's Performance Hardware products are designed using our in-house 3D scanner and modeling software. With these industry-leading resources in-house at our disposal, design aspects and fitment tolerances are at the maximum precision of up to four one-thousands of an inch. The result ensures maximum fitment precision on each and every Unitronic Performance Hardware product. After platform constraints and OEM components are 3D scanned, all data is imported into our modeling software, where we can analyze and interact with the chassis constraints to design an upgraded performance-oriented exhaust system to fit these constraints, as mentioned, perfectly; while ensuring that technical aspects and engineering principles are deployed.
    The exhaust gasses continue through the 200-cell metallic matrix high-flow catalysts, located in the factory position for maximum efficiency along with an OEM-inspired heat shields to reduce radiant heat dispersing into the engine bay.
    Unitronic's Downpipe is designed to utilize the OEM mounting locations to ensure a seamless direct bolt-on upgrade, while securely fastening the downpipe to the engine. Unitronic's Downpipe also features an 4-inch corrugated stainless steel flex section to further ensure long-term longevity and integrity.
    Unitronic's Exhaust Systems feature a unique v-band fastening system, using T316 stainless steel flanges and a locking ring to guarantee a centric alignment of the two v-band flanges to ensure a leak proof connection every time. Fully reusable and quick to install.
    Throughout the research and development process of Unitronic's Exhaust Systems, sound both in- and outside of the cabin is also a very important factor. Unitronic's mufflers feature high density, high temperature glass fiber packing and are stamped with the Unitronic logo and use a straight-through, free flowing muffler design. These attributes combined ensure maximum performance and sportier sound is achieved, all while maintaining a comfortable tone inside the cabin. Existing at the rear, exhaust gasses pass through polished 3.5” double wall polished tips featuring an engraved Unitronic logo for a more aggressive, motorsports-esque look.
    Combine with Unitronic Stage 2 Performance Software boosting performance to 337HP / 370LB-TQ on your A3.
    Features
    - Direct bolt-on fitment with OEM mounting locations
    - 3-inch T304 stainless steel tubing
    - T316 stainless steel flanges
    - 200-cell metallic matrix high-flow catalysts
    - Factory catalysts position for maximum efficiency
    - OEM-inspired catalytic converter heat shields to reduce radiant heat
    - Proper Oxygen sensor placement
    - Corrugated stainless steel flex section
    - TIG welded construction
    - Unique v-band fastening system featuring Clampco® clamps
    - Straight-through, free flowing muffler design
    - Polished 3.5-inch double wall polished exhaust tips w/ engraved Unitronic logo
    Applications & Pricing
    Unitronic Downpipe for 8V Audi A3, S3, TTS, MK7 Golf R: 959.99$ (USD)
    Unitronic Cat-Back Exhaust System for 8V Audi A3: 1099.99$ (USD)
    Unitronic Turbo-Back Exhaust System for 8V Audi A3: 1899.99$ (USD)
    For more information, be sure to contact your local Authorized Unitronic Dealer to get yours now!
    Established Member Two Rings LOT4R's Avatar
    Jan 12 2015
    Chalfont, PA
    That sounds amazing! Is that a TBE or CBE in the video? Also, when do you expect the S3 version to be released?
    2015 Audi S3 Prestige: 3M Scotchgard Pro | H&R Spacers 10F & 15R
    Flickr
    Jan 15 2010
    Santa Barbara, CA
    In for the S3 version. :)
    Apr 12 2016
    North America
    Could you please post more clips for this exhaust (include soft launch, hard launch, and just reving)? Thanks.
    Mar 15 2016
    Quote Originally Posted by VWVW View Post
    I second that.
