Results 1 to 16 of 16
    Jun 04 2016
    A
    During an oil change, slight beige creamy looking liquid substance in the oil
    Hi guys,
    Firstly, I had carried out a search on this forum regarding other peoples experiences.
    Rather than in the oil pain as liquid form, there are a lot of posts regarding whitish substance/build up on oil caps etc, that I assume may be a little different?
    responses I've noticed are usually; Moisture, PCV, short commutes, coolant, gaskets or oil coolers.
    The only reason I am little concerned is that I noticed during this recent oil change, that was about 2000km (1,242 Miles) after the alleged dealership service and I had never noticed it in any of the Japanese cars I've owned in the past.
    After that oil change, I struggled to get the drain plug to 100% seal (I had mentioned in my other post). So taking the plug OFF and putting it back on several times, I lost a bit of oil that I collected in a drain pan. The oil is now 80km (49 Miles) old and I still noticed the very small amount of beige creamy substance.
    The cars mileage is currently at 37,000km (23,000 miles), stock with no engine mods.
    so my questions are:
    1.) Should I replace the PVC valve anyhow? I heard that it is a weak part and should be changed/upgraded.
    2.) Should I install a Oil catch can, in order to prevent blow by? I heard even for stock motors, that you should have one in place, especially on a turbocharged vehicle.
    3.) is there anything else that could possibly be contributing to this if it isn't normal?
    Thanks again
    Established Member Two Rings 8T_BoCO's Avatar
    Mar 23 2015
    2012 A4 Avant S-Line
    Colorado
    1) There should be an open recall (17F9) for the Crankcase Pressure Regulating Valve for 2011-2014 models. The bladder inside can tear, throw a code, and have rough idle as a symptom.
    2) I'd be hesitant to out-think Audi engineers, but others here will likely have well-reasoned opinions.
    3) I'm not aware of other causes, beyond what you already read, but I'll be watching this thread to learn.
    While it is good to inspect the pan, when doing oil changes myself I use a top-side extractor (Pella) to avoid dealing with plug threading. You could check out installing a Fumoto valve as an alternative to your plug.
    2019 MT6 Golf Sportwagen S 4motion | Dark Blue
    Jul 16 2008
    Finland
    Are you loosing coolant? If not, I would not worry about it. At 37k km the PCV is also very unlikely to have failed, and you can easily detect a failed PCV from a whistling sound and fault codes.
    As for oil catch cans, I would not get one. If you do get one, get one that retains the factory breather setup and just directs it through the catch can and back to the engine. Some of the "pcv delete kits" out there are designed incorrectly, removing part of the breather system and can cause problems with oil seals, etc.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    My 034 motorsport catch can works beautifully... Maybe I'm lucky. The oil its sending into the intake was going to be there anyways, you're just catching an amount of it. I dump quite a bit of nasty sludge out of mine every time I service it. About 10oz worth.
    2016 S3
    Instagram- @Thisisastickup
    Jun 04 2016
    A
    Quote Originally Posted by b6Hate4 View Post
    yes I was thinking of getting an 034 catchcan, so the 10z per oil change, is that on a stock motor on 91 octane?
    Quote Originally Posted by TDIaholic View Post
    Nah, no coolant loss as far as a I can see and the water doesn't have any light oily residue that is usually present for blown headgaskets.
    How many km/Mi does it take for the PCV valve to commonly fail?
    Jun 04 2016
    A
    Quote Originally Posted by 8T_BoCO View Post
    Do you have the link handy for the recall?
    Also, the Fumoto valve works well? doesn't impede or obstruct anything, Do you also have a link to one for the B8?
    cheers
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Either too many short trips, where the engine is not hot enough, for long enough, to clear the normal moisture byproducts of combustion, out of the crankcase.
    OR
    You have an engine coolant leak into the lubrication system or oil-pan.
    OR
    Your PCV system is not working properly.
    As a proactive move, you should replace your PCV unit with the latest design revision, as there have been some improvements to make the PCV unit more durable. Some failure modes of PCV unit can cause the rear main crankshaft seal to fail, causing a $$$ repair (the transmission must be removed to change the rear seal.) Be aware that some sellers do not have the latest revision part...best bet is to buy it from a VAG dealer (and overpay a little).
    Jun 04 2016
    A
    Quote Originally Posted by S4'ed View Post
    OR
    OR
    Thanks, that ws the answer I was looking for.
    however, Im fairly new to Audis and Euros... do you have a direct link for the revised PCV?
    I did a search and found it quite confusing.
    Some doesn't state if its revised, some say it fits up to 2012' ... some are kits etc etc.
    if you can assist me, that would be great.
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by doublespeeded View Post
    No sir. Stage 2 motor, full bolt ons except ko4, with 93.
    2016 S3
    Mar 23 2015
    Colorado
    @doublespeed, you can enter your VIN here and the required recall (in this instance a 'Service Campaign') should appear:
    http://web.audiusa.com/recall/
    I've not used a Fumoto myself (I leave the bolt in place and extract oil from the top). ECS sells them. Perhaps they could tell you how happy their customers are with them on B8s:
    https://www.ecstuning.com/News/VW_Au...l_Drain_Valve/
    Below is the 'up to 2012, B8' part, as part of the whole assembly. Only the round cap seems to need replacing (it has a circular bladder underneath, where the tear/failure occurs), but I don't see that. Maybe your Audi dealer has it.
    https://www.ecstuning.com/Audi-B8_A4....0T/ES2707418/
    Sep 24 2014
    Central NJ
    Audi dealers don't sell the improved diaphragm as a separate part. There are other design improvements in the latest rev of the whole assembly (other than the more durable diaphragm), like an improved one-way check valve, that keeps turbo boost pressure out of the crankcase.
    Mar 23 2015
    Colorado
    Thanks S4'ed for the correction.
    Jun 04 2016
    A
    I tried the recall website previously and again just then, it doesn't recognise my VIN number.
    Yes im now interested in this Fumoto drain valve. It will save me buying an oil retriever.
    Ok im still a little confused with he PCV part. The one you included does say up to 2012' (which is what my car is; a 2012' built/with a 2013' Facelift/ CDNC 2.0T) at the bottom of the part/ECS page, it says the part will ONLY Fit TSI motors... but mine has TFSI emblem on the engine cover?
    (this is why I meant in my other post that my A4 model can be a bit confusing.)
    could you shed some light with this?
    Cheers.
    Jun 04 2016
    A
    As in a complete PCV part supplied to replace the old?
    Do you have the link?
    cheers
    Mar 23 2015
    Colorado
    Is there a reason not to have your dealer just do the work (since there is no charge)?
    I agree that the ECS description is confusing re: TSI vs TFSI. Sorry.
    If in doubt about the part, I'd call my Audi dealer and ask, when doing the 17F9 emissions service action for your VIN, what part # will be used.
    Jun 04 2016
    A
    Hey champ,
    I guess I can ask, but in Aus, it seems the mentality is that if you don't buy from us... we wont bother to try and help you. ( I recall someone saying that to me once too)
    That's why I figured if you had the actual part ready on say, the ECS page, I will just purchase it direct (do ECS sell one for the CDNC TFSI CDNC 2.0T?). Im also not worried about purchasing internationally than local dealers.
    Thanks again
