Results 1 to 30 of 30
    Aug 16 2016
    Navajo Nation, AZ
    Catastrophic Failure to valves and pistons. Advice and guidance needed Pls.... :'(
    The timing belt stripped and the tensioner pulley stripped the threads on the head whIle cruising at 65mph and rolled for about 100 ft. I bought everything needed for a complete timing belt change and found out about the interference engine. I decided to pull the head and found cylinder 2 completely gouged and thrashed. The head valves for that cylinder are done for and melted. The head seems to be useless now and the other 3 cylinders have a deep scratch/gouge in them. This is my first ever car purchase and experience with Audi. Im thinking of buying another complete engine. What should I do?
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    If the cylinder walls are all scratched up a used motor might be the cheapest route to take.
    Aug 16 2016
    Navajo Nation, AZ
    My error. The Pistons are scratched/gouged. Not the walls.
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by YungSavage View Post
    When this happened to me I used a dremel tool and a few different grits of sandpaper to get the gouges and scratches out of the pistons and get it back smooth. Got any pictures of the carnage?
    Oct 10 2013
    State College PA
    The issue with doing that is now the Pistons have different masses which can throw off the balance of the rotating assemble. I'm sure it's possible to do? But you also don't know if the piston has a crack in it or not.
    Oct 24 2011
    New Jersey
    Quote Originally Posted by Davdraco1 View Post
    Well, I've been running these pistons for nearly 90k miles now in two different motors without issue. There was not much material taken off at all, just little bits of smoothing on the dings. It really depends how carnaged his pistons are.
    Oct 10 2013
    State College PA
    i agree if they arent that bad, but i dont know how bad the OP's are so i figured i would let him know about that.
    Oct 24 2011
    New Jersey
    For sure. Hopefully he posts up some shots.
    Sent from my LG-H815 using Tapatalk
    Aug 16 2016
    Navajo Nation, AZ
    How do I post pics? I can't seem to find how to do it.
    Oct 24 2011
    New Jersey
    So you first need to host the pics from a web based host like imageshack or Flickr or something similar. Then once you do that you'll copy the url of the photo and place it between an image tag.
    Let us know if you can't get that to do it.
    Aug 16 2016
    Navajo Nation, AZ
    I tried different methods to upload the pics to imageshack and on audizine but it won't allow me. Idk what's up with my phone.
    - - - Updated - - -
    Where can I get a good deal on pistons?
    Oct 24 2011
    New Jersey
    If you are using your phone you can upload them right from Tapatalk to the forum.
    If you are going to pick up used pistons just make sure you pick up the right ones. I know for certain AEB engine codes use a 20mm wrist pin while AWM engine codes (2001 MY) use a 19mm wrist pin. I am unsure of the size of ATW wrist pins.
    Aug 16 2016
    Navajo Nation, AZ
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Aug 16 2016
    Navajo Nation, AZ
    Aug 16 2016
    Navajo Nation, AZ
    I'm sure it'll buff out... lol
    Aug 16 2016
    Navajo Nation, AZ
    Oct 24 2011
    New Jersey
    Wow... That thing is toast! I'm over here like 'just take it out with a dremmel'
    If the cylinder walls are good, you could get away with a hone, new rings and used pistons and a used head as that thing is toast too. But as Was said earlier, it will be cheaper and get you on the road quicker to just find an entire motor. Really sorry to see this.
    Oct 10 2013
    State College PA
    I thought i did damage to my engine, holy hell. Time for a new motor, so much easier.
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Just so happens I've got an AEB head and used AEB rods and pistons ;) all in good working condition. Throw some rings and bearings at it and voila!
    Aug 16 2016
    Navajo Nation, AZ
    If I were to buy another engine, which should I buy?
    How much are we talking R....15?
    Jan 12 2014
    Fargo, ND
    Whatever fair market price is, I'm not trying to gouge anyone or make money. Parts just sitting there collecting dust!
    Oct 10 2013
    State College PA
    Any transverse or manual longitude 06a with fit in. If transverse, you'll need to swap over all the brackets so the mounts line up obviously. I paid 400$ for an awp with around 120k on it
    Aug 16 2016
    Navajo Nation, AZ
    I'm super new to Audi and cars in general but I'm learning super fast as well. If anyone has any links that might help, send em my way pls. :D
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    What year is your car?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Aug 16 2016
    Navajo Nation, AZ
    2001 1.8t quattro
    Jan 12 2014
    Fargo, ND
    If you need an entire new engine, look on car-part.com
    Aug 16 2016
    Navajo Nation, AZ
    Does anyone have good experiences with rockauto.com?? Is there other places I can get good deals at as well?
    Dec 23 2009
    Boulder, CO
    Prices at rockauto are usually lowest by a mile. I don't trust all the brands they use though.
    Aug 16 2016
    Navajo Nation, AZ
    Such as?
    Oct 10 2013
    State College PA
    I love Rockauto. Haven't had an issue yet
