Results 1 to 4 of 4
    Aug 15 2016
    Auckland New Zealand
    Angry Car wont start - AUDI A3 2004 FSI 2.0
    Hi guys,
    Untill recently my car was working fine not any problems what so ever. The other day when I tried to start my car it wouldnt start. It kind of turns over but very slow like a chugging sort of sound but wont start. Its definitely not a flat battery as Ive tried jumping it. Im on about 1/4 tank of fuel (which is what i normally run). No fuses are blown as far as im aware of. BUT yesterday when I was looking around in the engine bay I found a cracked and completely broken PVC Pipe/hose coming from the top of engine - Could this be the reason for the car not starting (Pictures Included) Im pretty sure the starters in good shape, and the I can hear the fuel pump humming when I turn the key to the on position - Any help would be appreciated
    Cheers
    Photos in my photo gallery
    May 09 2015
    Hilliard, Ohio
    Sorry to hear about the issue. I looked up the part # on that crank case breather hose and it's a fairly cheap way to start with diagnosing your issue. 06F-103-217 from what I can see is the part # and it'll cause some rough idle but also oil over-consumption which will cause other troubles. I feel that you'll get a better answer of what's not working properly with a scan.
    Aug 15 2016
    Cheers appreciate the info - Could this be the reason for the car not starting? or should the engine still run without it?
    May 09 2015
    Hilliard, Ohio
    No problem. Yep, the Engine should still run.
