First, and especially second, are a bit fussy going in, maybe a little moreso on a downshift to second vs a 1-2 upshift. There is no grinding or anything. Also the stick shakes a bit in 2nd when you're on it, vs third and up, which all work great. When shifting out of second, it feels like the selector hub wasn't as far on, compared to other gears, if that makes any sense. Like you have to move it less to disengage.
The stick does move a little when you get on / let off in all gears (ie the whole box is moving, I guess. new trans and snub mount, maybe..?).
Anyway, does this sound like a linkage problem and is there a guide how to adjust it, or is it more likely that something is screwy with the 1-2 hub/fork/synchros/etc internally? I guess I should pull the linkage off and see how the selector feels right at the box?
thanks for any suggestions
