Results 1 to 40 of 51
    Jun 18 2015
    DavidhogAJ
    Philippines
    Terrible launch power in the summer heat from stock 2.0t Quattro w/Tiptronic
    It seems like trying to take off from a stop is actually dangerously slow in the summer heat, we're talking it seems like there is a 2 second delay before there is any real power... If I was to do one mod would it be HFC or a Stage I tune? Or should I wait to do both at once to make a real difference?
    I have been searching this forum but can't seem to figure out would be best to help for my particular problem I'd like to solve. Thank in advance!
    Edit: Man, I've known about heatsoak, but after experiencing it in a non-turbo car the previous couple of summers and not owning a turbo in a long time, I didn't realize how simple of a solution a FMIC would be to fix it! Thanks for all the great tips, including solid budget option as well!
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Intercooler upgrade :)
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Quote Originally Posted by shahk62 View Post
    ^this. It has helped my poor car here in our CA triple digit weather.
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by QuattriumMT6 View Post
    OK, can that be done without huge modifications? If not practical, what is the next best practical thing I can do?
    Jun 18 2015
    DavidhogAJ
    Philippines
    I know I'll get around to that eventually, I love to mod... but where should I start from stock that isn't so invasive? Where I am, we use California emissions so it has a really restrictive cat converter, but there is also no visual check, so as long as I don't get a CEL I can upgrade to an HFC... But, would a 91 octane tune help more to do first, or should I get the HFC to help first and that way when I do tune it will be able to take in effect the better flow from the HFC?
    Aug 24 2013
    Stockton, CA
    Quote Originally Posted by danbfree View Post
    JHM stage 1 tune (no mods needed) for instant power and to help with heat soak a JHM front mount intercooler which is a direct bolt on.
    Jul 14 2015
    Sydney
    An intercooler isn't a huge modification. If you got upgraded SMICs for example they'd fit into the stock locations and would just require you to take off the bumper
    Jun 18 2015
    DavidhogAJ
    Philippines
    Awesome, thanks for the tip! I didn't know there was a direct bolt on FMIC, I assumed a lot of fitting for that... So if I get the tune first then do HFC and/or FMIC will I need to re-tune or will it take into account the added/cooler flow happening?
    Senior Member Three Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Doesn't the JHM FMIC require cutting of the crash bar?
    Aug 24 2013
    Stockton, CA
    No need to re-tune. The car will adapt once installed. One of JHM's sponsors should be more than happy to help you out with your performance upgrade inquiries. They've made my car more fun to drive that's for sure.
    Aug 24 2013
    Stockton, CA
    Quote Originally Posted by wjg22 View Post
    That's the beauty of their FMIC options between small or large core...they both fit perfectly behind or underneath the crash bar. No alterations need to be done to the crash bar with either of their setups.
    Aug 24 2013
    Stockton, CA
    I know rapid posts but they're from my phone.... Here's a picture for quick reference of fitment with the crash bar
    Jun 17 2013
    jersey city nj
    ER smic are a drop in and cool just as as fmic. There website claim can support 600hp BT
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Their website says that proper installation requires modification of the front crash bar (large core)? I just assumed that meant that you'd have to cut away at it a bit to get the FMIC to fit behind the bar
    Jun 17 2013
    jersey city nj
    That kinda . I my AWE without cutting anything
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    That's why I've been keeping an eye out for an AWE one in the classifieds ;-)
    Jun 17 2013
    jersey city nj
    You just missed 1 for a $100.00. It just needed some TLC
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Really? Well damn.
    Jun 17 2013
    jersey city nj
    Really? Well damn.
    http://www.audizine.com/forum/showth...?highlight=awe
    Imo an easy . Sandwich between 2 pieces of thick plywood and use a shop press to straighten. Owner claimed it didnt leak boost. He's been a for a few years. Dont think he's gonna you. If if does after you straight. Send to radiator shop to . Mite not to pretty after its all done with but you cant it anyway after its behind the bumper cover. Ill get the job done
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Ahh, I do remember seeing that. Yeah I probably could've rolled the dice with that one.
    Jun 18 2015
    DavidhogAJ
    Philippines
    It looks like the small core JHM might be a good way to go, but I'm not looking for massive power gains, I'm approaching middle age with an 8 year old son so I just want responsive and respectable performance, say 250 awhp eventually... I did confirm I need to upgrade my DV to handle more boost, so I'm looking at efficiency improvements first so I will probably do a HFC first if that alone will help with responsiveness to start with, then do tune same time as DV and then FMIC and HPFP... Now I have to decide which HFC to start with, JHM, or one of the other two I'm forgetting the name of but I do know there is one for only $279 with hardware on ECS tuning.
    Sent from my SM-G920P using Tapatalk
    Senior Member Three Rings Gmoney1147's Avatar
    Dec 09 2014
    Roseville California
    what stage tune are you from jhm?
    Dec 09 2014
    Go test pipe. Just save your factory cat an reinstall it again for whenever you need to resmog. That's what I am doing for California. After removing the factory cat my car feels so much more responsive and faster. I have some friends with high flow cat that are wanting to go test pipe now. Personally I was looking at high flow cat as well but then just said screw it an bought a test pipe.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    I have the Awe which is a huge core and fits perfectly... you get what you pay for.
    You can also do the ebay kit which is priced accordingly and similar to more pricey units. .. just have to figure out how much you want to spend.
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Ebay FMIC kit? I gotta look into that...
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by Gmoney1147 View Post
    I'm sorry but I have absolutely ZERO desire for a smelly and sooty car for 2 more HP and a turbo that spools a little faster... You guys are about ALL out performance, but an HFC is still a vast improvement over stock and I actually WANT to run clean. I thought I made it clear at the beginning of my post, but I'll explain in further detail why... My friends go test pipe/swap to stock for smog in their Subbies and DSM's because they are about all-out performance and their cars are stinky and dirty to show for it. I bought a classy Audi sedan because that's exactly what I want it to be, not a polluting, dirty boy-racer... Absolutely no offense personally, but since you went there, I thought I'd explain further... It's a philosophical thing like politics, you aren't going to change many people's minds. :) That said, an HFC alone is good for like 20+HP/30+TQ, so I strongly feel that a HFC along with a tune on top of that will get me where I want to be while still running clean.
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by Hugh@EuropaParts View Post
    Since you guys don't offer performance IC's, I'm looking at the small core JHM for $600 as the best balance of price, performance, quality and ease of installation... any argument with that? I'm not looking for 400+AWHP, I'll definitely be happy with 250-275... Edit: I'm seeing direct fit kits on eBay for around $280 that look decent, are those the ones you say are OK or are those junk?
    Veteran Member Three Rings Winners Eat Pho's Avatar
    May 17 2008
    What kind of power can be expected with the FMIC? I always assumed the logical progression is chip > downpipe > exhaust > FMIC.
    Aug 22 2010
    Piscataway, NJ
    FMIC doesn't yield any gains... it just allows the car to not lose as much due to warmer temps.
    Aug 24 2013
    Stockton, CA
    Stage 1. That pic looks like my car but isn't lol
    Dec 09 2014
    Would be interested to do some side by side logging with you. I have a tune from a different company an contemplating tuning with them. I'm in the sac area
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by pezgoon View Post
    Ya, this one is a direct fit, I wonder if it's junk?
    http://www.ebay.com/itm/06-10-Audi-A...-/151927025532
    Aug 24 2013
    Stockton, CA
    PM'ing you to keep this thread from getting cluttered.
    2008 A4 2.0TQ Ti - 6MT
    1991 MR2 Turbo - 5MT
    1997 Pathfinder 4x4 - 5MT
    ~Marc
    Aug 22 2010
    Piscataway, NJ
    tons of people running that intercooler without issue...
    Jun 18 2015
    DavidhogAJ
    Philippines
    Awesome, thanks for the input... will purchase what I can from you guys! :)
    Dec 09 2014
    why the "without issue..." cause if its good i am about to go buy one as well
    Mar 01 2011
    Nanuet NY
    I dont know if its classy tho
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    this my dood, this...jhm tune....just the tune dials it up a lot, a lot more aggressive out of the hole, throughout the entire powerband....more linear delivery.....just do it!!!! i promise you wont be disappointed....make sure plugs and coils and fuel filter are in good condition too
    2008 Ibis RS4....GETing tuned
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by axnjaksn View Post
    Thanks man, I definitely will go that route!
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by reno808 View Post
    Don't worry, hidden behind the bumper and doesn't spew soot and exhaust smell so classiness doesn't apply... but thanks for playing. ;)
