Results 1 to 23 of 23
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    B7 RS4 - AMD LP/HP Supercharger Kit (plug and play)
    Selling my AMD supercharger kit - http://www.fastaudi.com/#!Addict-Mot...f21f6856d9056c
    3 years - 10,000 miles - Perfect running condition
    Included (everything in pictures):
    AMD LP/HP Supercharger kit
    LP and HP water to air system pumps, pulleys, belts
    Fully assembled High Pressure Fuel Pumps for HP pulley
    All water to air tubing
    Intake tube
    Custom PCV tubing
    P3 vent gauge with boost reading module
    NOT included:
    ECU flashing cable
    Tune
    Intake manifold gaskets
    Spark plugs
    Installation instructions/manual
    Warranty
    All the above retails for $14,570.00. Asking price including shipping (can work out a deal if local pickup): $10,000.00
    8/16/16: Updated asking price: $8,500.00
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    How are you? Is the P3 Cars gauge a multi gauge? If so, is it for sale separately?
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Active Member One Ring SprintRS4's Avatar
    Apr 28 2016
    2007 Sprint blue RS4, 2011 6MT S4, 2003 Chevy Duramax
    Edmonton, Alberta, Canada
    This kit is $10,999 new from addict according to their website and your selling it for $10,000 at 3 years old and 10,000 miles? pardon sounding like a dick but im just curious if im missing something here?
    2007 Sprint Blue RS4- H&R coilovers, Magnaflow catback, Bronze AG M590 wheels
    2011 6MT S4- Tsw Nurburging wheels
    Active Member Four Rings wahpao's Avatar
    Nov 01 2006
    SNJ
    Quote Originally Posted by SprintRS4 View Post
    $10.999 is for the LP kit. The HP kit, which he is selling is $12,999 plus he has a P3 vent gauge and custom tubing it reads. The catch is the tuning that you'll have to purchase separately. Let's just say it's $1k to have them retune. So you be roughly saving $2k for a 3 yr/10k mile kit or buy a new one for $2k more? Is there any warranty on the hardware at all?
    Jan 29 2006
    08 RS4
    No worries I'm not trying to be greedy either. I could be wrong on my asking price as well. Let me explain how I'm figuring my price...
    AMD HP retails at 13,000 and does not include: shipping, high pressure fuel pump housings (you have to modify your originals), heat exchanger fluid plumbing, PVC plumbing. When you include all of that you're looking at about 14,000 retail shipped to your door.
    P3 gauge with boost and vent retails for 570.00. You wont have to cut up your original vent.
    So I'm looking at a total of 14,570.00 for everything brand new shipped to your door (minus spark plugs and labor if you pay a shop to do it).
    At 10,000.00 for everything in this ad including shipping, that's a savings of 4,570.00. Wahpao brings up some good points though that I should consider for the final price, there now is NO warranty on the kit and one will have to spend 800-1,200 for the tune (assuming based on tunes available for purchase for the RS4 now).
    With that being said, I am willing to work with the price. If you or anyone else is serious about purchasing the kit, throw me an offer and we'll talk. I'll also consider an even better deal if it's a local transfer.
    Nov 01 2006
    SNJ
    Quote Originally Posted by KryptoniK View Post
    AMD HP retails at 13,000 and does not include: shipping, high pressure fuel pump housings (you have to modify your originals).
    Are the HPFP part of the HP kit now?
    Supercharger Kit Contents
    Eaton/Magnuson TVS R1900 supercharger
    5-axis machined AL intake manifold
    High flow cast AL intake
    Exclusive low profile actuator system
    HPFMs High capacity fuel lines
    High flow waterpumps
    Large front mount heat exchanger (HP Only)
    2 Aviva HPFP (HP Only)
    OEM RS4 Idler Pulleys and Belt
    Engineered stainless steel brackets
    OE iat sensor relocated post intercooler
    High quality coolant lines and AN interconnections
    Plug and play wiring system
    Stainless steel hardware
    Intake gaskets
    AMD/UM Software
    Jan 29 2006
    08 RS4
    wahpao AMD only supplies the modified internals for the HPFP. You have to disassemble your existing ones and install their new internals. In this case I'm shipping out the HPFP housings with the updated internals already installed. Saves some time on installation.
    Jan 29 2006
    08 RS4
    Updated, new asking price: $8,500.00
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    Why was this removed? Sale of car?
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Jan 29 2006
    08 RS4
    Quote Originally Posted by dsgray16 View Post
    Yes parting out most of my mods for potential car sale.
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Question, does this kit necessitate built internals? How much power and what clutch were you running?
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Apr 28 2016
    Im guessing you can run the LP with stock engine but what Do you need to run the HP kit? also what supporting mods other than clutch, fly wheel, Dp/exhaust and tune would I need to run this?
    Cheers, Max
    Jan 29 2006
    08 RS4
    Quote Originally Posted by Fourplay View Post
    It does not, stock motor is fine. I've been running JHM stage 4, never slipped. Then again I never launch the car.
    Jan 29 2006
    08 RS4
    Cheers, Max
    Hey Max,
    HP runs on stock engine according to AMD, no need for upgraded internals. I never had any issues with my motor FWIW.
    No other supporting mods needed other than the ones you mentioned although a light weight fly wheel is not necessary.
    Dave
    Apr 28 2016
    How come people dont just run the HP setup if its same supporting mods? Im all the way up in Alberta Canada so how would I go about getting it tuned? wasnt thinking about going S/C till next year but have a buddy interested in buying my truck and if he does I might have to pull the trigger on this lol
    Jan 29 2006
    08 RS4
    Well as far as the car goes it is ready for LP and HP... the kits themselves are what have some differences.
    LP uses the passenger aux radiator to cool it's water to air cores.
    HP requires the addition of a front mount heat exchanger, bigger water pump for the cores, high pressure fuel pump modifications.
    Why people don't go straight to HP? I wonder the same... It's a few grand more expensive but the overall power output is amazing and worth it. I guess if people want to run a lower power application that is less complicated to install and less expensive they have an option for them.
    I can ship to Canada that's not a problem. As far as flashing the tune, AMD sells a cable that you can hook up to your laptop and flash the ECU from home.
    Definitely keep me posted, if anyone else is serious about purchasing it I'll let you know first before moving on to someone else.
    Nov 01 2006
    SNJ
    Sorry was trying to blow your spot up. That's kind of vague how they list it on the their page. One would not think that those are the HPFP internals only by that description. $2k to go from LP to HP from AMD seemed a bit low for the parts that were included. I think JHM is asking $3500 for Stage 1+ (Intercooled with upgraded fueling and a smaller pulley) upgrade. I know everyone will get into JHM vs AMD debate so I'll stop right there. Good luck with sale.
    Jan 29 2006
    08 RS4
    Quote Originally Posted by wahpao View Post
    Oh no worries I didn't take it that way. Haha yea lets keep it clean, thanks for helping with some of the questions wahpao and bringing up some good points I didn't consider.
    Established Member Two Rings IbisRS4's Avatar
    May 10 2009
    RS4
    If you're selling, can I buy your rims?
    Junior Member One Ring
    Dec 29 2015
    Porsche 911 turbo (RED)/ Audi RS4... (RED)/Audi RS5(RED)/ Audi S5 / Audi S7 / 8J Audi TT RS
    union / nj
    pm sent....
    Sep 20 2015
    This is a good deal. I have this kit and its turn my car into a monster. A few things to add here. Installation is the biggest key and not hardware. I can say this hardware was built to last. Only wear items are belts and regular maintenance items. The pumps are easy to rebuild and upgrade. Most shops can probably do the LP version and only 1 person still has the LP version to date. AMD prefers you go to a shop in the network so you have a better experience. I went outside the network and didn't really have much problems. You would save big time buying this kit for this price. Also it looks stealth under the hood. Best of luck
    Feb 24 2010
    And have never been happier
    Love it
    Switched to Tesla and have never been happier. No more shady mechanic bills and excuses - oil top off before an oil change is normal or dealing with outdated forums that have image size limitations. And no more dealing with vendors that do not provide horsepower numbers but sell you random things by labeling them as performance parts. No more dealing with the Audi dealership and having to buy custom Audi specific tools. Wow. I can't believe I lived through all of this. Money pit.
    Jan 29 2006
    08 RS4
    **SOLD**
