Results 1 to 7 of 7
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    Auxillary Fan Orientation
    I've searched.
    The fins on the fan wheel are spaced differently, is there a certain way I'm supposed to align it to the viscous fan?
    Regards,
    ~ ea
    1999 A4 FWD AEB 1.8T ~ Atlas
    Established Member Two Rings jsbs1991's Avatar
    May 19 2014
    cbr 600f3
    Snellville GA
    this is a picture of my aeb engine I'm building from a Passat. hope this can help
    1999.5 A4 1.8TQ APR III, Ecs diff mount, apr snub mount, raceland ultimos, forge splitter.
    Apr 22 2014
    Aptos, CA
    Word.
    I'm sure it will!
    Thank you.
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    The fan spins in a circle so at any given point it will be orientated differently. Doesn't make a difference.
    Apr 22 2014
    Aptos, CA
    I figured as much, but why build a fan with alternating spaces?
    Similar to: Why build a frankenturbo w/ mixed flow?
    something with alternating power or something?
    Oct 24 2011
    New Jersey
    The mixed flow design allows lower pressure ratios to be able to spin the turbine sooner. It makes sense for allowing an earlier spool on a wheel made to flow more in the top end. At least that's my understanding.
    As for th3 fan there must be a reason due to how it manipulates the air or else it wouldn't have been designed that way
    Sent from my LG-H815 using Tapatalk
    Apr 22 2014
    Aptos, CA
    Quote Originally Posted by Believer View Post
    Interesting.
    My thought was: An air version of the human hand spinning a non-functioning fan, like phew phew phew to get it going and continually spinning. As like the bigger gaps are the "hands" that come in and give the fan more force to keep it spinning well.
    ^ never studied physics, completely un-educated theory.
