Hey all,
I am new to this forum however have had my Audi for quite some time. I own a 2002 A4 3.0 Quattro with the 5 speed automatic which currently has around 180,000kms.
The car has been trouble free mostly except for the last few thousand Kms where i have been experiencing weird stuttering issues whilst driving. Basically while accelerating at certain temperatures and at normal acceleration around 2-3k the car feels like it has no power or just gradually stutters until the gear change, once the car has warmed up i also feel the gears while the engine is downshifting to come to a complete stop during which i also sometimes feel a loss in brake pressure as if i don't have full braking power, under load however the car seems to pull pretty well. I have tried a few things so far however i still cannot solve the issue. When ice cold however the car seems to run better but once the temp gauge moves it starts to play up.
Things i have tried so far are:
1. MAF sensor cleaning
2. New fuel filter
3. New air filter
4. Tried to find and fix most of the vacuum lines i believe were broken/leaking.
I am also not getting any codes through VCDS however i did however notice that my intake temp was around 57 degrees celsius which i thought would be quite too warm however due to the absence of any codes i overlooked this. Basically i am just wondering if anyone else has had this issue before and knows how to fix it because I'm not sure where to go next.
Thanks in advance guys n gals :)
