Results 1 to 40 of 64
    Dec 16 2014
    Irvine, CA
    TTV racing flywheel and B7 RS4 clutch
    TTV racing flywheel and B7 RS4 clutch.
    Anyone running this combo? I am about to pull the trigger on it and wanted to see from people running it how they like it. How is chatter? Any other issues anyone experienced?
    Jul 04 2012
    Woodbridge, VA
    Bordom runs it. PM him
    Senior Member Two Rings WEBER's Avatar
    Jul 01 2008
    Imola B5 S4 ,90 CQ 20vt KTM Superduke
    Portland, OR
    I feel like I've posted an answer to this question like 5 times now...
    2001.5 S4 Imola
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    No one runs it.
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by vavJETTAw36 View Post
    I have not installed it yet. Saving for turbos to do at the same time
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jul 04 2012
    Woodbridge, VA
    What the hell man get off your lazy ass! :) just kidding man. I'm actually really interested on the feel. I will probably switch to it as long as it will hold 530 crank. Didn't mean to call you out thought you had done it.
    Dec 10 2013
    Lol No worries.
    IG: 24_et
    Sold:
    RIP:
    Sep 11 2009
    NE
    nobody runs it specifically but lots do TTV B5 FW side and B7 (modified) PP side, which is basically same thing sans the height and modified bolts pattern. As such, I can tell you that stock will probably be smooth like butter since that's what you're aiming to run. I can say that since my stage 3 with 8 puck fibertuff is super smooth and it has far more positive engagement than stock organic stuff.
    Now, will it hold 500+ on crank... that will be a close call and as such, you should NOT do it and go directly for better clamping clutch, which I bet you will have some choices as there must be inexpensive B7 RS4 clutches out there that can hold more than 500. AMD rates their stage 1, which is mounted to modified (higher clamping than stock) PP at 550ft/lb. AMD is proven, so I would strongly advise to not donkey around with clutches and get proven set up. Get AMD Stage 3 (or even better stage 3+) and don't do the clutch ever again, if you're driving normally without abusing stuff to no end.
    Simply saying, do it right, not twice.
    Dec 10 2013
    Quote Originally Posted by julex View Post
    Ok, cool.
    So much for developing the platform and providing new ideas for performance, reliability and cost. Most aftermarket clutches for this use a B5 RS4 pressure plate.
    IG: 24_et
    Sold:
    RIP:
    Jul 23 2012
    Pullman, WA
    I am running a ttv b7 flywheel with the cheap b7 rs4 clutch kit from rock auto. Holding well on my 5858 single turbo at 30 psi :)
    Jul 01 2008
    Portland, OR
    I'm running TTV B7 RS4 flywheel and JHM B7 stg 4.
    2001.5 S4 Imola
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    i recently learned the hard way you have to order the proper flywheel that is made for b7 pressure plate as the b5 plate stack height is 2mm less
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Shim it (washers between pp and fw) or put a 2mm thinner disk in?
    Not that I would ever want to drive one daily, but the clutchnet ceramic disks run about 2mm thinner than an oem disk.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jan 11 2007
    Salt Lake City, Utah
    I've been away from the forum for a minute, but glad to see these people posting:) That is all.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Feb 04 2016
    London
    This is exactly what I was about to do! Guys I heard a lot of stories about clutch chatter, what are your experiences with this? In your replies please state the weight of your flywheel.
    Nov 16 2010
    WetSide, WA
    Imo, the worst chattering setup is a fidanza and a disk that has an aftermarket style hub.
    I would honestly attribute most of the chatter people hear to the springs in the center of the aftermarket hubs not being as effective as the oem style.
    I run a jhm alum fw with and oem hub disk and there is next to no chatter.
    Pretty much takes effort if I want it to, and I drive like grandma and cross the 1800-2200rpm zone they get cranky in all the time.
    The ttv fw with an oem hub disk prob doesnt make noise at all if you know how to drive.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by DxC View Post
    So this is what happened when TTV screwed up my flywheel 2 years ago.. they sent me a B7 flywheel instead of a B5 version... Thanks for posting this info.
    Feb 04 2016
    London
    Quote Originally Posted by zillarob View Post
    Ok I can't read it if it's not in English.
    Nov 16 2010
    WetSide, WA
    I drive in a manner that often has my setup in the rpm range that makes them chatter. It rarely does, or I have to try to make it happen purposely.
    Is that more betterer?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I will be running a ttv fw and b7 rs4 pp w/ 6 puck disk. Just mocked it up last weekend with zillarob
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Apr 21 2013
    Longmont, CO
    Quote Originally Posted by CELison View Post
    What disc did you go with? I've been looking for different options.
    Nov 16 2010
    WetSide, WA
    Think it was from Sean. The srm, b:b5, and clutch.net all look very similar to me.
    What kinda power are you shooting for and how do you plan on driving?
    There may be some better driving options out there if you arent planning on putting a whoopin on it like Jesse.
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by Audi_From_Hell View Post
    6 puck from Sean
    B9 S4- EPL/AWE
    Apr 21 2013
    Longmont, CO
    I have k04-028/029's sitting here but I'm much more interested in either 6258's or tte 600's. I will be tuning for 91 most of the time but will be running an e85 tune in the summer. I will be running full rs4 intake including manifold, 2.8 cams, rods, and all necessary supporting modifications.
    I drive like I stole the car pretty much everyday. I occasionally take the s4 out to track days but mostly drive canyons and high speed pulls. Car is on coils, rear sway bar, adjustable upper control arms all the way around, rear adjustable sway bar end links and rear tie rods, spherical front sway links, 17z up front, 4 pot rears, aluminum uprights, and I'm sure I'm forgetting things. 4:1 diff is next along with b6 3.0 01e. I'm not worried about having a "heavy clutch" or something super streetable, I have 3 cq's, a 4kq, and a b8.5 a4 so I'm constantly changing between cars.
    Not a fan of clutchnet though, seen them blow up.
    Sep 09 2014
    Grand Rapids, Michigan
    I run a ttv flywheel and an AMD stage 2 clutch. Perfect setup imo. No chatter at all. Plus the drivability is fantastic. Easy to engage/slip like a stock setup, light on the foot, but holds like it's not even trying.
    Dec 16 2014
    Irvine, CA
    Look what arrived :)
    Going to use a B7 RS4 clutch with it.
    Feb 04 2016
    London
    Are the oe friction discs sprung? I would assume they'd be solid as that's the role of the dual mass.
    Dec 10 2013
    Quote Originally Posted by Hooblah View Post
    B7 RS4 clutch disk is sprung
    IG: 24_et
    Sold:
    RIP:
    Nov 16 2010
    WetSide, WA
    Audi seems to like doubling them up to be safe.
    Disk with oem center will chatter the least, aftermarket sprung center a lil worse, rigid disk is prob going to aggravate it.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    Quote Originally Posted by Bordom View Post
    Ok, cool.
    on just PJk04 my b5 rs4 PP aftermarket clutch stopped working at 12k miles. Heavy track and stunting use (clutch pops etc.). I like my southbend stage 4 extreme or whatever clutch I replaced it with (think it has a racing style aftermarket PP), but I'm with Julex as far as AMD goes, I really like those guys and their clutch product has the testing done already.
    Nov 16 2010
    WetSide, WA
    That it survived 12k with you at the wheel is a testament to the badassery that is the b5rs4 pp
    Whats that, like 3 sets of tires for you
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Geez
    Sent from my SM-G930T using Tapatalk
    Nov 04 2013
    Palo Alto, CA
    probably 6 sets, minimum . Yeah no it felt great 'til it just started slipping -- like it was never super strong holding, but 'stocklike' on k04 power. We couldn't really pin down the problem but tried a few things before just scrapping it. It's possible I just glazed em so bad that I couldn't nurse it back to life, but it happened right after a clutch-pop, spun up, and just never recovered. It was people smarter than me that said it was the PP -- best I got for data, file it accordingly =P
    Sep 16 2010
    Central Wash
    I'm going to order this setup pretty quick here.
    Has anyone actually use the TTV B7 Rs4 setup yet? RockAuto still has the clutch kit for $900. It's ridiculous TOO EXPENSIVE TO BUY SO DON'T BOTHER.
    Jun 08 2014
    Vancouver, Washington
    Quote Originally Posted by rollerton View Post
    Has anyone actually use the TTV B7 Rs4 setup yet? RockAuto still has the clutch kit for $140. It's ridiculous.
    SHHHH dont give away the secret come on now!
    Sep 16 2010
    Central Wash
    Quote Originally Posted by MarlinFoundNemo View Post
    (*ok...I fixed it.. ssshhh....)
    Jun 08 2014
    Glad you fixed the typo! Way overpriced compared to other sources!
    Nov 16 2010
    WetSide, WA
    lol
    May 16 2008
    South Texas
    There's alot more different in the flywheels than the stack height. Dowel pins are wrong size and the strap cutouts are entirely different.
