Results 1 to 9 of 9
    Veteran Member Three Rings Winners Eat Pho's Avatar
    May 17 2008
    Brake Pad and Rotor Replacement Kit
    Happy Monday -
    I'm looking for a direct OEM replacement kit for front & rears.
    This is what I'm looking at from ECS: Front & Rear Brake Service Kit Featuring Meyle rotors and Vaico semi metallic pads $327
    Do you guys have any other recs?
    Mar 24 2013
    Oakdale, CT
    Consider ceramic pads if you don't like brake dust. What you linked should be fine for an oem style replacement.
    -Adam
    Veteran Member Three Rings Deckster's Avatar
    Oct 08 2012
    Sacramento, CA
    I'm using Zimmerman rotors and Akebono break pads. Can't go wrong. Unless you want OEM than that's a different story. You may want to check other sites too like Europa Parts. There's a thread if you search for it about break pads and rotors.
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    That kit should work out fine for OEM. I recommend replacing the rubber bushings that the guide pins slide into. It's a part that gets overlooked.
    Jan 21 2014
    GA
    No doubt about the Akebono pads. For the rotors, CEntric premium is also a nice option.
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    We offer build your own direct fit brake kits for anyone interested...
    ULTIMATE BRAKE KIT (A4 B7)
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Oct 24 2015
    Perth, WA
    If only it wasn't 500USD to ship to Australia. :(
    My respray thread
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    For what it's worth I'm trying to sell a new set of rear Hawk 5.0 pads for the B7 A4 :)
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Mar 01 2011
    Nanuet NY
    Waiting to see when a sale pops up to get front and rear brake set
