Results 1 to 19 of 19
    Veteran Member Three Rings notn41's Avatar
    Jul 09 2013
    2012 V Rod Night Rod Special, 2009 GSXR 1000
    Las Vegas
    2013 audi s7 wiring experts. Nav screen won't flip up?
    I hadn't connected the screen sensor properly it is fixed now!
    2013 S7 Phantom Black
    Options:Innovation Package, Comfort Seats, Radar Assist
    Interior Mods: Atlas Carbon Inlays, Full leather/alcantara red stitch interior, Full led interior lights, facelift sweeping tail lights
    Exterior Mods: H&R Lowering module, 15mm spacers, Black OEM RS4 wheels 20", Stinger VIP, Milltek Valvesonic High flow catted TBE
    Feb 25 2010
    magimmeMVE
    Usa
    Make sure your mmi panel is back on, no breaks int he MOST ring if you disconnected it. Have its retract button back on and it should work.
    Jul 09 2013
    Las Vegas
    Can you show me a picture of the MOST ring? Or the parts that need to be connected? The motor doesn't even try to move, I don't hear anything.
    Also on the back of the mmi, all of the plugs are connected except one, I think it's a green one, it's a single plug. Is that possibly the issue? I didn't see a Green plug anywhere. I'll see if I can take a pic when I get home
    Feb 25 2010
    magimmeMVE
    Usa
    The MOST ring is the fibre optics that link the cars MMi system together. If one is not connected or faulty the whole lot goes down. If your MMi unit is reconnected make sure the fibre leads are firmly in. If so then look elsewhere such as the switches i mentioned. Have you scanned the car for faults?
    Jul 09 2013
    Las Vegas
    I would have a million right now. My car is completely disassembled and I don't have a scanner yet.
    This is the inside.
    Does this unit need to be fully plugged in for the screen to move? Seats and steering wheel aren't in the car either. I can't figure out what exactly needs to be installed to let the screen flip out. I remember when I first took was able to move the screen I had the mmi in and the driver seat and steering wheel still installed. That's the only difference I can think of. Everything else was out of the car. Something odd about the mmi, is that all the plugs plug in except one
    The bottom center right green one closest to where the big harness plugs in. I looked everywhere and I don't see a plug that goes in there. Am I going crazy or does nothing plug in there?
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Bro you have some huge balls!!!!!!
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Feb 25 2010
    magimmeMVE
    Usa
    The green connector deals with the video input usually from the rear analogue camera. Plug the mmi back in and test it. Steering and seats dont have to be in. The connector on the far right is the fibre MOST ring and not connecting this ( which also includes the CAN Gateway in the ring) will not allow a lot of systems to operate or 'come alive'
    Jul 09 2013
    Las Vegas
    Quote Originally Posted by Djpeaksd View Post
    Wait till you see the rest of the interior..
    Jul 09 2013
    Las Vegas
    Quote Originally Posted by morski View Post
    I had all of those in and nothing with the screen flipping up. Only thing that doesn't work is the flip up of the screen. Like I said only connector that wasn't in and I couldn't find was the green one.
    Feb 25 2010
    magimmeMVE
    Usa
    and the screen retract button next to the vent?
    Mar 29 2014
    Hampshire, UK
    Depending on just how disassembled the car is, you may have disconnects the MOST fibre ring somewhere. It runs from component to component. If any one component is off - or missing, you break the MOST link and it won't work.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    Quote Originally Posted by notn41 View Post
    I almost had a panic attack looking at how stripped down it looks..
    Kudos to you O.P.
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    Jul 09 2013
    Las Vegas
    It doesn't do anything when I press it but it's plugged in. Nor does the screen try to move automatically.
    Jul 09 2013
    Las Vegas
    Quote Originally Posted by jkwelsh View Post
    Can you be more specific where the MOST fiber ring is? I have basically everything out.
    Not even the seat or steering wheel is in there anymore.
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    This is the inside.
    As long as you have everything taken apart, try pulling the screen out of the dash and turning the drum that has the cord attached.
    Aug 29 2011
    Cape Town South Africa
    There may be to many components removed, ie Aircon controllers and seat memory.
    2014 Glacier White A7 3.0 TDI.
    Jul 09 2013
    Las Vegas
    Quote Originally Posted by tenspeed View Post
    I tried pulling it apart and nothing happened. I couldn't get the screen to move.
    Quote Originally Posted by Speedemon View Post
    Yes that what I had originally thought. But it's weird because the button doesn't work but everything else seems to work??
    Jul 09 2013
    Las Vegas
    UPDATE ON THIS ISSUE:
    Got car back together and screen turns on and flips up, all functions work so it seems, then after 20 seconds it powers down, and you hear the motor still going. Almost like the power just CUTS out like it's cutting it on purpose.
    Any help would be great. Can't bring it to dealer till I figure this out, it has aftermarket stereo.
    Mar 29 2014
    Hampshire, UK
    Have you changed any of the MMI components? It sounds like component protection kicking.
    Also, all the MMI components are interconnected using fibre optics in a daisy chain configuration. If one piece of the daisy chain fails, all the subsequent components don't work.
    Check the fibre cable (orange in a black plastic tube) is not kinked, pinched, bent or unplugged from any of the MMI components. You can also check fuses for every component.
