Results 1 to 24 of 24
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    No AC fan from rear seat or floor vents.
    So yesterday we had passengers in the rear seats and they noticed that there was no AC fan coming from the rear floor vents. When I set the climate control button to direct air to the lower vents only, I had nothing coming from the lower vents either in the front or the rear. Dash and upper vent fans work fine. So basically the fans work for the upper and center, but not the lower.
    Any ideas? I have not plugged in VAGCOM for any codes yet.
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    May 20 2010
    Could be an issue with the HVAC flap motor/door, and it may not be functioning to direct air down to the floor vents.
    Apr 08 2016
    Mission Viejo, CA
    It absolutely could be, is this a servo issue or something I can check with VAGCOM? Not sure where to start with this problem.
    2008 Audi B7
    2003 Ford F250 XLT
    May 20 2010
    Using it on the HVAC module may already be logging a code, but if not, the output tests should let you cycle through it. If it is that which is bad, either live w/o floor air or you'll need to remove the dash to get to the HVAC blower and door unit
    Apr 08 2016
    Mission Viejo, CA
    Let me pull some some codes first... Removing the dash on a daily driver is a no-can-do. However pulling the glove box to check the servo's power is a can-do. or can I see that actuation through VAGCOM?
    2008 Audi B7
    2003 Ford F250 XLT
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    I had this same exact issue last year and the dealer fixed it under warranty by replacing the Climate Control Flap Motor, or so it claimed to be on the work order.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Senior Member Three Rings DrZEUS's Avatar
    Aug 18 2011
    B8.5 S4
    Mississauga
    Had a similar issue but it happened to me in the winter (noticed I was not getting heat from certain vents). I had to replace two servos.
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by DrZEUS View Post
    Where are these servos and flap motor located?
    2008 Audi B7
    2003 Ford F250 XLT
    Aug 18 2011
    B8.5 S4
    Mississauga
    Servos are under the glove box. There are 5 of them. Search for a glove box DIY on how to remove it.
    Then scan for codes in your central convenience module. I had two codes but didn't know which servos they were. You can see which flaps are moving and which ones aren't but I don't recall if it was so obvious which servo controlled which flap. So what I did was unplug the harness from one servo at a time, scan for codes until I saw which servo coincided to which code in VAG-COM. Replaced the ones that were faulty.
    Apr 08 2016
    Mission Viejo, CA
    Sounds like a plan, thanks.
    2008 Audi B7
    2003 Ford F250 XLT
    Aug 18 2011
    B8.5 S4
    Mississauga
    Np good luck
    Apr 08 2016
    Mission Viejo, CA
    So I pulled this...
    2008 Audi B7
    2003 Ford F250 XLT
    Aug 18 2011
    B8.5 S4
    Mississauga
    Check out this from Rosstech:
    http://wiki.ross-tech.com/wiki/index.php/01272
    Did you perform an output test in Measuring Blocks?
    Apr 08 2016
    Mission Viejo, CA
    I did not, but will do tonight. Thanks.
    2008 Audi B7
    2003 Ford F250 XLT
    Feb 24 2004
    Minneapolis
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Apr 08 2016
    Mission Viejo, CA
    Which block did you want to see? If I am reading this correctly, V70 and V113 are reading high which could indicate a failed servo motor.
    2008 Audi B7
    2003 Ford F250 XLT
    Apr 08 2016
    Mission Viejo, CA
    Any help with the blocks?
    2008 Audi B7
    2003 Ford F250 XLT
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    its really weird that it says a maximum value/stop value, and like half of them are outside that range...
    Did you try what mtroxel posted?
    Group 6 seems to be the one that jumps out, it is WAY past its maximum value, maybe its stuck maxed out? If they are labeled correctly and the first groups were temperature doors I don't think they would affect flow at all
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by pezgoon View Post
    I have not tried changing out the flap motor yet, still trying to diagnose. It's possible the values are messed up simple due to a bad motor...
    2008 Audi B7
    2003 Ford F250 XLT
    Apr 08 2016
    Mission Viejo, CA
    I swapped out the V70 servo, cleared codes but still have the same issue. Here are the new block readings that are out of range and the only diag code stored.
    2008 Audi B7
    2003 Ford F250 XLT
    Feb 24 2004
    Minneapolis
    Check out this thread. The second post tells you how to reset the HVAC adaptations to default.
    http://www.audizine.com/forum/showth...1871-HVAC-Code
    Apr 08 2016
    Mission Viejo, CA
    Thanks, I will try that and post results.
    2008 Audi B7
    2003 Ford F250 XLT
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by mtroxel View Post
    Bingo! Resetting all adaptation values to zero in MB 001 brought everything to queue. Thank you for your help!!!
    2008 Audi B7
    2003 Ford F250 XLT
    Oct 24 2015
    Perth, WA
    Nice.
    My respray thread
