    Jun 06 2016
    Florida
    New clutch/FW making grinding noise
    I just had a brand new Eurocode flywheel installed with a stage 2 Southbend drag clutch. I went ahead and also replaced the throwout bearing, pilot and flywheel needle bearings, clutch fork and release arm, the relese pin, flywheel bolts, slave cylinder and stainless steel UPS clutch line as well. When the shop installed everything, the car wouldn't start with the pedal fully depressed, so they ended up lengthening the slave cylinder rod.
    My friend picked the car up for me since I'm out of state, and he said that it makes noise when depressed. I brushed it off since I understand there will be significant chatter, but when he sent me the video it's clear something is wrong. He also says that you can shift gears with the clutch pedal only 1/2 depressed. The car, however, will NOT start unless the pedal is fully depressed. The shop is going to take another gander tomorrow, but does anyone have any idea what this could be? Thanks
    P.S: I could upload the video if there is a way to do it from my iphone, imgur.com doesn't support the video file for some reason
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    The no start issue you are going to have to wire around the 3rd hall switch on the master cylinder. See newer posts from the "push my foot through the floor" thread
    2021 Audi S4, P34 Intake
    Jun 06 2016
    Florida
    Want to give everyone an update. I apperantly got the wrong clutch fork. There were 2 different versions depending on your VIN, and you need to use a specific pivot ball with each. That fixed all my issues.
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    I bought 0B1141719K (newest revision), previous revision was part # 0B1141719J, which one did you get?
    Thanks
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Jun 06 2016
    Florida
    Quote Originally Posted by RWD2quattro View Post
    Thanks
    I haven't picked up the car since its 13 hours away from me. I'll let you know if they included any paperwork and what part number, but I'm almost sure I bought the K, and he went to the other clutch fork and pivot ball that Audi says to use with that fork.
