Results 1 to 9 of 9
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    7 codes from ECU, surging, rough-ish idle. What do?
    Happened right after a 90 min, 70 MPH interstate drive, right as I was turning the car off. Several hours later when I went to leave, rough start with flashing CEL, CEL went steady. Had to drive home, engine would surge a bit if I pushed on the pedal to pass. Smooth drive otherwise and other issue getting home. Log below, thanks everyone.
    2009 2.0T, 89,256 miles.
    Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H14 0001
    Revision: E1H14---
    Coding: 010C010A190F0160
    Shop #: WSC 03327 444 125814
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
    ROD: EV_ECM20TFS0118K2907115AL.rod
    7 Faults Found:
    2967 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 00 [096] - Implausible Signal
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 143358 km
    Date: 2016.08.14
    Time: 09:49:08
    Engine speed: 3571.50 /min
    Normed load value: 99.6 %
    Vehicle speed: 78 km/h
    Coolant temperature: 95 °C
    Intake air temperature: 35 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 13.735 V
    Unlearning counter according OBD: 39
    2968 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 00 [237] - Implausible Signal
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 143346 km
    Date: 2016.08.14
    Time: 09:41:21
    Engine speed: 3048.00 /min
    Normed load value: 84.3 %
    Vehicle speed: 90 km/h
    Coolant temperature: 97 °C
    Intake air temperature: 33 °C
    Voltage terminal 30: 13.970 V
    Unlearning counter according OBD: 40
    4054 - Cylinder 1
    P0301 00 [237] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143485 km
    Date: 2016.08.14
    Time: 15:40:37
    Engine speed: 1390.50 /min
    Normed load value: 9.8 %
    Vehicle speed: 29 km/h
    Coolant temperature: 65 °C
    Intake air temperature: 40 °C
    Voltage terminal 30: 13.782 V
    4060 - Cylinder 3
    P0303 00 [101] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143507 km
    Date: 2016.08.14
    Time: 16:09:28
    Engine speed: 1801.50 /min
    Normed load value: 36.5 %
    Vehicle speed: 24 km/h
    Coolant temperature: 96 °C
    Intake air temperature: 46 °C
    Voltage terminal 30: 13.711 V
    Unlearning counter according OBD: 80
    4063 - Cylinder 4
    P0304 00 [100] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143485 km
    Date: 2016.08.14
    Time: 15:40:37
    Unlearning counter according OBD: 79
    4057 - Cylinder 2
    P0302 00 [237] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143485 km
    Date: 2016.08.14
    Time: 15:40:37
    4051 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [237] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143485 km
    Date: 2016.08.14
    Time: 15:40:14
    Engine speed: 854.50 /min
    Normed load value: 18.0 %
    Vehicle speed: 3 km/h
    Coolant temperature: 60 °C
    Voltage terminal 30: 13.617 V
    Readiness: 0000 0000
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Sounds like your intake manifold flap mechanism died....common problem...you might have an extended warrantee on this from Audi...
    Sep 09 2010
    Destin, FL
    May 26 2015
    Mormon Country
    Quote Originally Posted by S4'ed View Post
    Yeah, I'm going to call them tomorrow and see what they can do for me.
    - - - Updated - - -
    Quote Originally Posted by The Infiltrator View Post
    Yo yo man, yeah I checked the Ross-Tech Wiki, but it's kind of generic about it. I wasn't sure if it was carbon build up related or something else.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by GilliamOS View Post
    - - - Updated - - -
    I got ya man. Just trying to keep stuff like this is the thread that's made.
    Feb 24 2013
    CA
    X3 either that or check your pcv diaphram
    Sep 24 2014
    Central NJ
    P2015 clearly points to an intake manifold tumble-flap problem, which will cause misfires if the flap is in the wrong position.
    A bad PCV will usually have an "excessive air at idle/lean condition", or "idle speed too high/uncontrolled" trouble code.
    May 26 2015
    Mormon Country
    Intake runner adjuster is busted, AoA doesn't want to help even though they running a 10 year/120k mile recall on CCTA and CFBA engines with the same flaw.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    www.automotix.com has intake manifolds for like $200 with a 1 year warranty.
    My 2009 A4 Prem+ Build thread
