Results 1 to 2 of 2
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Fuel pump top cap for AN fittings?
    Looking for some recommendations on billet top caps for using AN fittings.
    I see SRM makes one for the b5, does anyone know if this will work? Any other options? I'd like to avoid having one made of at all possible. If I can get enough interest in them however, maybe I'll have it done.
    Dec 05 2007
    The location of the pump I conjecture would not be a good place for billet. Sees too much of the outside elements. Suspect it would rust rather easy unless anodized. And really no need for fancy cover there. Nobody will see it and will he covered in dirt in a short time. Easiest to just attach a barb to AN fitting with hose to stock plastic nipples.
    Edit: nvmd, thought this was the b5 section.
