Results 1 to 15 of 15
Thread: Oil Change Kits
    Senior Member Two Rings robertstitt's Avatar
    Jul 24 2016
    Richmond Hill
    Oil Change Kits
    New to the S4 and have been looking at oil change kits. There seem to be a ton of them. I'll be changing my oil using a topside method so won't need a new drain plug/crush washer so just the oil and oil filter. I've used various oils in my wife's Passat Komfort wagon and my JSW. Motul and Pentosin lately. Came across something a bit new to me, Ravenol synthetic. BLAUPARTS http://www.blauparts.com/proddetail....od=J1A5084%2DE has a kit that looks interesting. Has anyone used this kit? What are your thoughts? What oil change kits are you using and post a link. Thanks.
    Mar 21 2015
    Heres a few of the popular ones. Scroll down the page and take your pick. Liqui molly, motul, castrol are some great ones to name a few.
    https://www.europaparts.com/oil-chan...ercharged.html
    Edit,
    Heres the approved list
    https://www.audiusa.com/content/dam/...e-Bulletin.pdf
    Mar 27 2013
    Order a filter from Amazon and get Mobil 1 0w040 from Walmart. Done.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by s14roller View Post
    Yep, I've had pretty good luck with this method so far.
    SOLD 2015 Daytona Gray S4
    Mar 27 2008
    San Diego
    Quote Originally Posted by SteveYem View Post
    Amazon for filters and Mobil1 0W40 European here as well.
    I also used a Mitivac topside extractor and it makes the oil change process a real breeze and very clean.
    Jul 24 2016
    Richmond Hill
    I've been using a Mitivac for a couple of years on my JSW and Passat Komfort Wagen. Works great and no more crawling under cars. Just wish the oil filter wasn't a paper element. The wife's Passat (2.0 T) has a a spin on filter on top of the engine that is just super. Wish that the S4 had the same but can live with the filter element. I'll have to look at Amazon for the oil filter. Mann or Mahle? Also have to check out the Mobil 1 0W40 European. Kind of doubt that the local Wally World stocks the "European", I am in "Jaawja" afterall.
    Jun 17 2010
    Madison WI
    Quote Originally Posted by jeffc31337 View Post
    All of the above for me also. Slick as snot.
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
    Oct 08 2007
    Minnesota
    I've been using the blauparts kits on every S4 i've owned and never had an issue. They are fairly close to me though so basically next day delivery and often times free shipping helps.
    2014 RS5
    2012 S4 DSG EPL Stg 2 DP
    B5 A4 Lemons Racer 2019 Minneapolis 500 "pray for rain" Award winner
    Jul 24 2016
    Richmond Hill
    I haven't looked yet but can anyone tell me what size is the cap on the oil filter and number of flutes?
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Did my first oil change the other day (3.0T)
    Oil extractor from harbor freight
    Filter from dealer ($15)
    Mobil 1 0w-40 from walmart
    36mm or adjustable wrench for the filter cap.
    Sent from my SAMSUNG-SM-T337A using Tapatalk
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by q5 dave View Post
    I didnt even know Harbor Freight had one.. i will have to go pick one up since my Audi care is kaput!
    Aug 08 2016
    Oshkosh, WI
    sorry for being naive on this and could totally look up, but figured this was much easier.
    Do you insert sucker end of pump down until it stops?
    How much Mobil 1 do you put in? I have a jabsco pump so difficult to measure off of (use for boat and jetskis)
    Also I am feeling stupid about this one, but where is the dip stick?
    I have a 2013 S4.
    Thanks
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by lopott View Post
    I have a 2013 S4.
    Thanks
    there is no dipstick, just an plug to cover the hole. stuff the hose all the way in, and then some more.
    I filled with 7.2 quarts (check owners manual to be sure)
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Me too. I started using the Mitivac pneumatic extractor when I had my C6..still works phenomenally well on my C7 3.0T. I was shocked on my first oil change when I pulled out almost 8 liters of oil from that 3.0.. That motor holds a lot of oil!!
    Also, I just got my Mobil1 rebate checks from back in April when they were running that special. Took almost 4 months, but 2x 12$ checks from the 2 jugs I bought. Awesome deal.
