Results 1 to 8 of 8
    Nov 06 2013
    Australia
    Engine misfire. One off event, all clear now??
    Hello
    I had just been driving enthusiastically for about 30 minutes. Twisty sections of road with lots of accelerating/braking with the engine sitting at around 4000-6000rpm through the gears. The The EPC light came on and the engine then started to misfire, with a noticeable loss of power. I drove for about 5 minutes to see if it went away but it didn't (no where to pull over anyway). It was also misfiring on idle when I'd pulled over. My Torque pro app came up with a "P0302 - Powertrain, Cylinder 2 Misfire Detected" fault. It didn't flag up any other issues.
    I turned the engine off, checked the engine, gave the coil leads a shake and started the car again. The EPC light remained on (same fault) but the misfire had gone. Drove for an hour (to return home) with no misfire. I wasn't driving as hard, low revs with the odd burst of acceleration. Got home, turned engine off and on again and the EPC light had gone.
    The car is a 2013 B8.5 S4 with APR stage 2 , APR TCU, AWE exhaust and an intake. Its got around 30,000km on clock. It had recently -less than 500km ago- had a minor service with an oil change.
    I've tried searching the internet, but most have come back with fixes for a permanent fault (ignition coils, sparks etc).
    I'm going to have a look at the spark plugs, but since it seems to be back to normal, I'm guessing it might have been caused by something else. Any ideas before I start replacing everything?
    Thanks
    Jun 06 2016
    Florida
    I had the same issue on my A4, and on my S4 I woke up to a "differential" fault which went away after I turned it off, then back on never to be seen again.
    If I were you, I would change all the spark plugs and gap to .028 if stage 2, .032 if stock and I would swap cylinder 2 ignition cool with the one next to it. If you get an EPC and it's not cylinder 2, it's more than likely the cool. If it stays with cylinder 2, maybe wiring, or clogged fuel injector, possible carbon buildup causing major air blockage or something else.
    Nov 06 2013
    Australia
    Thanks I'll give that a try
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    Quote Originally Posted by b8s4me View Post
    Can you explain how this helps and why stage 2 should be gapped differently? I have not heard of it, that's all
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Hello.
    Maybe a leaking SC heat exchanger. It happens sometimes on this engine.
    Perhaps those Who experienced it Could chime in and expose symptoms more in details ?
    BR
    Mat.
    Envoyé de mon SM-G850F en utilisant Tapatalk
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    May 12 2016
    Quote Originally Posted by Mat@1975 View Post
    Hello.
    BR
    Mat.
    There are a couple of people who have had cracked SC intercooler cores also but I don't know how either causes misfires but would like to know actually. Is it through leaking coolant into the manifold??
    I have a misfire issue and rough idle issue, and have pretty much replaced half the ignition system to no avail, I don't recommend that approach!
    Misfire reasons I've researched for our cars: carbon buildup, bad fuel, spark plugs, a/f ratio sensors, fuel pump, clogged cats
    Nov 06 2013
    Australia
    spark plugs and a spare set of ignition coils are on order. Will be able to check the existing plugs the weekend and report back.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    in regards to the leaking intercoolers, once it leaks, it'll spray coolant directly into the intake ports, fouling the spark plugs once it reaches into the cylinder. Mine was directly on cylinder #5, it first was only under WOT conditions, however it quickly fouled that plug. The plug itself was wet, with a white moldy-looking texture to it. It was hard to identify though as it was on the top of the intercooler, which can only be visibly seen once you remove the intercooler from the S/C.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
