Results 1 to 3 of 3
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Audi Allroad - hatch lock cylinder removal
    I want to remove the license plate tub/fob lights/license plate holder.
    Inner trim is all off, all nuts off.
    Just hanging on the lock cylinder it appears.
    How to remove the hatch lock cylinder?
    Note: currently cannot get the key into the lock, rusted from years of non use.
    suggestions, links, video appreciated.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    I managed to get the key in the lock and the lock to turn (a few hours of PB Blaster soaking AND constant wiggling and pushing the key in).
    All my searches for instructions how to remove the lock (so I can get the license plate tub off) did NOT turn up anything on the HATCH LOCK.
    Car is 2002. Not sure if other years do not require to remove the lock; but it sure seems to be the case on my car.
    Any suggestion or links?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Lock has a C clip in the bottom. Removed. Key in lock, lock wiggles out. But housing still hanging on tub (not sure if glued on or just baked on over the years. Needed to knock it off the tub. Out now.
    05 Golf TDI
