Results 1 to 12 of 12
    Jan 06 2016
    Was I ripped off? OEM vs. aftermarket parts
    I recently had my AC condenser replaced, and I specifically asked if the price they quoted was for OEM parts. They said yes, but the AC condenser they gave me does not look like the original that it replaced. Can anyone confirm whether this is an OEM part or an aftermarket part? (Are there some distinctive markings I should be looking for?) I paid $485 for it, so it had better be OEM.
    Dec 25 2004
    Earth
    Thats how shops make cash! They charge you OEM prices for nonOEM parts! Hello!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Is that for 485$ for the part and install or for the condenser only?? I can tell you that it should not be black if it is the OEM piece it should be the natural aluminum finish.
    Jan 06 2016
    $485 was for the part only, although I know the OEM part can be found cheaper on ECS and elsewhere.
    Thanks for the info about the natural aluminum finish on the OEM part. Perhaps it is correct then.
    Aug 20 2012
    Mesa, Az
    Whoa.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by tHatOne guY View Post
    Both my b6s have black condensers and judging by how beat they are I'd say that they are the original part on the car. Pretty sure black is genuine Audi.
    Sent from my XT1058 using Tapatalk
    Aug 20 2012
    Mesa, Az
    I'd check with your local dealer. Could be dependent on your region. I'm in the SW US and I have purchased one Genuine Audi condenser which was silver and even an OEM Behr it too was silver. the only ones I've seen black are aftermarket only.
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    My oem one on the car is black as well. OEM never replaced.
    19' Glacier S4 Black Optics
    Apr 17 2016
    kc
    My condenser is black too. But it said "made in china" on the sticker😝
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Mine is aluminum finish and the car originated from Indiana.
    Jan 06 2016
    Seems like there's a lot of variance. Unless someone knows that all OEM versions are either black or aluminum or stamped with four rings or some other distinctive OEM marking, then I can't really know for sure that mine isn't one of several versions of a genuine OEM part. Thanks for all your responses.
    Aug 20 2012
    Mesa, Az
    You're certainly right, either way 485$ condenser only... I would return it and save myself a couple hundred by using an OEM from a reputable site.
