Results 1 to 18 of 18
Thread: APR Stage II
    Active Member Two Rings Hooks S4's Avatar
    Aug 09 2015
    CA
    APR Stage II
    So I have been following this site for a while but rarely post. I am at APR Stage I in a 2013 B8.5 S4 now and want to go to the more Torquey stage. If I purchase the overpriced pulley they provide, can I have my own mechanic install and then take it to the same place and have it flashed to Stage II? Are there any additional charges associated after the pulley purchase to anticipate? Thanks in advance!
    Sent from my SM-G935T using Tapatalk
    Mar 21 2015
    Yes your mechanic can do the install and you can take it to another shop to flash. It is safe to drive it with the pulley and that flash not installed yet. Your other shop may charge a fee to flash to stage 2 though, some do and some don't.
    Jun 20 2015
    NC
    Do you have 6mt or dsg? If you are 6mt you might need a clutch soon.
    Mar 21 2015
    And if dsg then you will want the tcu tune.
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    When you buy the pulley kit it includes a software code for the stage II tune. Don't loose that.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Jul 11 2016
    Mississauga
    Hoping to ask a side question. I have 2011 Audi A4 b8 and I recently got the fully loaded ECU with 4 programs for stage 1 by APR. how much will the flash be for stage 2 if I get the HFC installed? My APR wants $300-$400 for stage 2 flash. Is that right?
    Mar 21 2015
    Quote Originally Posted by umairg35 View Post
    https://www.goapr.com
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    You can install the pulley yourself. The software is included for free with it.
    You'll love the gains.
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    I went straight to stage 2 on a 6MT. Clutch is ok so far (knock on wood). My cost was 2.5 hours for the install of the pulley. And 1150 for the sale price of the software. I was told flashing was $55 to go back and forth from stock for dealer visits.
    If you are already stage 1, you would just have to pay that shop fee for their time to flash it.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Quote Originally Posted by eightamrock View Post
    This all depends on how you drive it. When driving normally to somewhat aggressively the stock clutch is fine.
    That said, I overheated the clutch and had a ton of slippage while launching the car. And this was when I was still stage 1. Today (currently stage 2) the clutch slipped quite a bit with some aggressive shifting. So conditions and driving style will play a large part in this.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by DBFL View Post
    same here on super cold mornings i can get a little slippage
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Aug 09 2015
    CA
    Thanks for the replies. I have the DSG. Just wanted to make sure I didn't need anyone specific to install the pulley. At 83k, any concerns with upgrading at this mileage? Car runs great otherwise...
    Jun 20 2015
    NC
    Plugs should be done. You will do a new belt with your pulley. Make sure your DSG services are up to date . Have fun
    Jan 21 2016
    Quote Originally Posted by Hooks S4 View Post
    I also recommend the ECS transmission inserts at minimum. Without, you are really going to feel that trans slap around when you punch it. It's pretty cheap and install is 10 minutes.
    RE: Clutch. Stage 1 on my GTI had me slipping almost immediately and it only had 12k miles on it. I drove that car really aggressively. I've been pretty tame with the s4, but a stock clutch is not made to hold up on a 30% power gain.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Quote Originally Posted by Sceanzo View Post
    Depends on your clutch practice. I've been stage 2 for years with 0 slip or clutch issues. I don't launch though. That being said - I'm only at 36k miles on the car...
    Established Member Two Rings roydle's Avatar
    Oct 25 2015
    FL
    Quote Originally Posted by Sean@APR View Post
    tempted in going to stage 2 as well. However, according to the APR site, the gains of stg 2 over stg 1 is just 17 hp and 18 tq. With those gains will the butt dyno feel it? Those number gains are a bit more than adding an intake which I did not feel any difference once installed.
    May 10 2012
    2013 s4, 2008 cbr1000rr
    United States
    Quote Originally Posted by roydle View Post
    Most of the gains felt will be daily driving under the curve power.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I went stock straight to stage 2 and feel the power is more everywhere so normal drivability is similar. My wife drove the car for the first time since going to stage 2. She said she did not like it, because she could too easily get in trouble.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
