Originally Posted by
Okedokey
Are you sure they're neoprene, it generally wont melt but ignite at around 500F.
No I'm not sure at all. It was just my way of describing it.
DanKing
Maybe it fully collapsed and a peice of the mount rubber was against something hot??
I don't see anything touching the mount at all. Nothing looks weird there at all. Heat shields are all fine.
pezgoon
Maybe your turbo is getting that hot? Beat the
out of it before it happened? The turbos can pretty easily glow red hot (thats about 500f) when being driven hard, that could heat that up pretty good if you get it hot enough. I feel like that's scary hot to do that though. I'd be worried about the life of the turbo at this/that point
I'm wondering. I did a APR Stage 1 in June. I drove it hard for a few weeks just to feel the extra power. But I've also had a lot of "boost control range not reached" since the Stage 1. That means I've been doing WOT runs to log my boost. And when I graph those runs, I'm usually a good 1 1/2 PSI under the boost request as shown below. I've read that underboost codes can mean the turbo is always spinning faster than it should to try to make the ECU happy. That's my current theory.
