Results 1 to 8 of 8
    Junior Member One Ring
    Jun 11 2015
    Chicago, IL
    A/C not turning on after water pump repair
    I have a 2010 S4. Car overheated last week, figured it was the water pump or thermostat so had a local shop replace them. The mechanic only replaced the pump (said it was easier) and it was still overheating, but he thought the t-stat was fine because water was flowing, then he tells me he thinks my head gasket is bad. Long story short, took it to the dealer, thermostat WAS bad, and the secondary expansion tank had a hose loose causing coolant to spill (probably the first mechanic didn't tighten it). They also tell me my A/C pressure/temp switch is bad and my AC doesn't work.
    I think that the first shop must have disconnected something, because my A/C worked great up until the moment the car overheated (AC started blowing less cold, and 30 seconds later the car is beginning to overheat). They wanted $550 to fix it.
    Picked up the car today, runs great, no overheating, but when I press the A/C button it just lights up for a moment and then immediately the light turns off. It blows air just fine, all the controls work, but no cold air and the button won't stay lit.
    TLDR: Does anyone know where the connection is to this sensor so I can check it for myself?
    This is the trouble code:
    Part #: 8T1820043AQ
    Coding: 66102000 (hex)
    Component: KLIMA 3 ZONEN
    Fault codes:
    00256 Givers for refrigerant pressure / temperature (G395)
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Does it blow cold in park or neutral?
    Mine would blow cold in park or neutral, but didn't in drive or reverse.
    I had to clear a code with a Vagcom, thanks to another forum members suggestion.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Jun 11 2015
    Chicago, IL
    A/C doesn't even switch on at all. Park/driving doesn't affect it. The AC unit in the dash turns on, displays everything correctly, fans blow, heat works. But, when you press the "A/C" button, it doesn't turn on. The light doesn't even stay lit after you let go.
    Mar 21 2015
    I remember just recently someone posted the same thing, I can't find the thread though.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Here's that post.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Mar 21 2015
    Link not working
    Jun 11 2015
    Chicago, IL
    If someone can find the post I'd appreciate it. I think I've located the sensor, will try to access it tomorrow and see if it's simply a connection issue. Definitely don't understand how this could be connected otherwise to my overheating problem. The car has been running great otherwise since replacing the thermostat. Need to fix this with how hot it has been here lately.
    Jun 11 2015
    Chicago, IL
    Replaced the sensor, still having the same problem. Any ideas?
