Autotech FSI High Pressure Fuel Pump Upgrade Kit
Autotech is the premier manufacturer of fuel pump upgrades for the FSI engine because our kit offers the highest quality, solid engineering, and great value.
Our HPFP Kit can achieve flow rates 50% higher than the original pump, essentially removing pump limitations from the equation, even on high-end turbo upgrades.
Sale Price: $359.95 shipped - To place an order & for more information Click Here
FSI RS4 Injector Set of 4 (079 906 036D)
This is a set of four (4) OEM (079 906 036 D) B7 RS4 fuel injectors which are primarily used when upgrading fuel systems for VW and Audi FSI motors. These injectors are a great and inexpensive solution for all your 2.0T FSI big turbo fueling needs. Tested to over 500whp, these injectors are commonly used with Unitronic, Eurodyne, and Revo big turbo software.
Sale Price: $349.95 shipped - To place an order & for more information Click Here
S3 Fuel Injector Set of 4 (06F 906 036 F)
These injectors flow 13% more the factory A3/MKV 2.0T FSI injectors. They bolt on with no modding and are the perfect upgrade to anyone going to a bigger turbo.
Complete your FSI K04 car with the help of the S3 injectors, to prevent the damages of running lean. If you're making your own K04 turbo kit for MK5 GTI, GLI, or B7 A4 then you'll need these S3 fuel injectors. Also required is an upgraded high pressure fuel pump and upgraded software.
Sale Price: $499.95 shipped - To place an order & for more information Click Here
CTS Turbo FSI Auxiliary Low Pressure Fuel System
We are proud to release the new FSI Auxiliary Low Pressure Fuel System. As you may already know the FSI fueling system has two separate fuel pumps, the LPFP (Low Pressure Fuel Pump) and HPFP (High Pressure fuel Pump). While there are a number of options for HPFP available, including the Autotech HPFP, there are limited options for fortifying the low pressure fuel system. CTS has developed a fully integrated fueling system, which utilizes a secondary in-tank fuel pump that is capable of supporting in excess of 600HP. This was done by using a load based fuel pump controller that only activates when your engine really needs the extra fuel. If you're looking for a fuel pump system to support all the power that your FSI engine can handle look no further than the CTS FSI Low Pressure Fuel System.
Product Details:
-High Output in-tank Fuel Pump
-CTS Load based fuel pump control system with all electrical wiring and connectors
-CTS High pressure fuel line
-CTS Proprietary fuel fittings
-Comprehensive installation instructions
Hitachi High Pressure Fuel Pump - OEM Replacement
OEM replacement High Pressure Fuel Pump assembly found in FSI (belt driven) 2.0T engines. This is a factory replacement made by Hitachi in Japan. Hitachi is the OE supplier to VW and Audi.
NOTE: New camshaft follower MUST be installed when replacing pump.
Sale Price: $299.95 shipped - To place an order & for more information Click Here
It there are any questions feel free to send us a message or email me at [email protected]
