Results 1 to 20 of 20
    Apr 22 2014
    Bath, UK
    Misfiring 3.0TFSI
    So today whilst driving it developed a bad misfire. Car was in Dynamic at the time, and being driven full throttle. Error message on the dash was EPC, but it wasn't serious enough for it to say "Stop Now".
    Stopped the car at the services. Popped the bonnet and nothing obviously wrong. Turned the car off and on again. Misfire was gone, drove home perfectly.
    VCDS scan below. Ignore the over-rev warning - that's after the misfire has started and is me putting the car in neutral and revving it (was afraid it was going to stall).
    Does anyone have any ideas? Turning it off and on again worked, but why?!
    Quote Originally Posted by VCDS
    Address 01: Engine (J623-CGWB) Labels: 06E-907-551-CGW.clb
    Part No SW: 4G0 907 551 F HW: 4H0 907 551
    Component: 3.0l V6 TFSIH07 0005
    Revision: --H07---
    Coding: 12250034052701020000
    Shop #: WSC 02311 785 00200
    ASAM Dataset: EV_ECM30TFS0214G0907551F 001005
    ROD: EV_ECM30TFS0214G0907551F.rod
    VCID: 2C57F9C547FE635EF2-8078
    5 Faults Found:
    6353 - Cylinder 4
    P0304 00 [096] - Misfire Detected
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 64802 km
    Date: 2016.08.12
    Time: 14:07:20
    6354 - Cylinder 5
    P0305 00 [096] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 64802 km
    Date: 2016.08.12
    Time: 14:07:20
    6371 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [096] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 64802 km
    Date: 2016.08.12
    Time: 14:07:20
    11837 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
    P0219 00 [096] - -)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 64804 km
    Date: 2016.08.12
    Time: 14:08:32
    7948 - Cylinder Disabling
    P130A 00 [096] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 64802 km
    Date: 2016.08.12
    Time: 14:07:20
    Readiness: 0000 0000
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    There is a laundry list of things that can cause a misfire.
    Bad gas
    bad coilpack
    spark plugs
    vacuum problems
    emission systems problems (purge valve)
    Since it only happened once I would clear and wait for it to happen again.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    why did it over rev?? did your trans mess up?
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Is that even possible on neutral?
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Apr 22 2014
    Bath, UK
    What I don't understand is why the misfire was on two cylinders; 4 and 5.
    • There's a list of things that will affect a single cylinder. E.g. an injector, a spark/coil. But this was two cylinders, not one.
    • There's a list of things that will affect three cylinders. E.g. a camshaft position sensor. But this wasn't a whole bank, it was only two cylinders.
    And then, why did turning it off and on again magically fix it?
    If it was bad fuel, surely it would have happened again on the rest of the journey?
    To those asking about the over-rev, don't worry about that. I know what it is.
    If you look at the timestamp, it's a minute after the misfire has started. What happened was the traffic slowed down, and the engine was misfiring so badly that it felt like it was going to stall or cut out. So I stuck the gearbox into manual mode and kept the revs up high'ish, to keep it alive. But then the traffic slowed down further, so I shifted into neutral (forgetting that the car has the limiter set much lower in neutral). So as the car had come from high'ish-revs in a low gear, when I shifted into neutral it was above the neutral rev limiter (3000RPM or whatever it is), and the limiter instantly cut in dropping the engine down to 3000RPM. And because it had arrived in neutral with the revs at 5000RPM, it logged an over-rev.
    Aug 06 2014
    NJ->CO
    I assume this is not your first Audi or VAG product since you have VCDS?
    Misfires and in your case a cylinder disable always resets after a restart. Nothing is really "fixed" and the faults are not cleared just the system gives another chance to see if the issue is no longer occurring after restart. Almost all modern cars are this way. And in your case the system no longer had an issue.
    The issue you felt really wasn't the single misfire. They happen from time to time and no one even notices. You more likely felt the system disable a cylinder. So it had shut off fuel and spark to at least one cylinder and whatever occurred to make the system do this was no longer an issue after restart.
    Now, why did it disable a cylinder...that I'm not sure...you said you were at full throttle when the issue occurred. A full throttle single misfire may warrant a cylinder disable so the system can protect itself from worse damage. You need more detailed logs or freeze frame data to really tell any more than that.
    I see you are in the UK so I assume you have pretty good gas quality but I don't know what year your car is...at 64k km it makes me think it is a 2012-13 so coil packs may not be out of the question. Seems unlike 2 would fail at once and generally when they are failing the issue comes back but it is not impossible.
    I still say run some dry gas through and some injector cleaner....I know, I know, injector cleaner doesn't clean the intake valves on a direct injected motor, but it does still help the injector itself. Perhaps some buildup on the injector dislodged at high rpm to cause your issue. Anyway just a theory...trying to help.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Veteran Member Three Rings AdrianLee's Avatar
    Jul 19 2011
    2016 A7 3.0T & 2016 Q5 3.0T (Wife's Daily)
    SW Michigan
    Quote Originally Posted by gk1 View Post
    When I had a similar issue with my A4, I had a stuck injector and it was stuck wide open. I had to rev it to keep it alive too. Was there a strong smell of fuel coming from exhaust?
    C7.5 A7, APR Stage 2, APR Heat Exchanger, Fluidamper, AWE Exhaust, Eurocode Swaybars, RS7 Airbox, Trans Tune
    Jul 19 2011
    SW Michigan
    any luck figuring it out?
    Apr 22 2014
    Bath, UK
    I didn't bother, as it only happened once.
    Until last week when it happened again. Exactly the same situation: Full throttle, misfire, turn it off and on again, then fine.
    Guess I better investigate properly now...
    Mar 08 2010
    AudiLand
    My S4 did this 3 times for the 3 years I owned it ( back in 2010). Was a common issue with those cars then without any solutions.
    Apr 22 2014
    Bath, UK
    Had a look at it. Second occurrence of the misfire was the same as the first: Misfire on cylinders 4 & 5 (possibly for just a split second), but then in reaction it shuts down the cylinder.
    Ran though the Audi diagnostics.
    Have pulled the spark plugs and coils, and swapped them around.
    So if it happens again on the same cylinders, then it's injectors or engine stuff. And if it happens again but on different cylinders, then it's spark/coil.
    May 02 2015
    New York
    Did you ever figure this out?
    Same problem on my 2013 S5. Dealer said they're going to do injectors and plugs.
    2013 S5 | Volcano Red | H&R Sport Springs, APR Stage 1, ECS Tuning Intake, JHM Test Pipes, Custom X-Pipe
    2000 TT | Denim Blue | Big Turbo, E85, 517AWHP [Sold]
    Senior Member Three Rings Low Flyer's Avatar
    Oct 25 2008
    MD
    Did anyone ever figure this out? My 2012 S4 has been at the local dealer for 2 months with the same issue. The combination valve is good, they check my timing, spot on, replaced #4 fuel injector, replace coils and spark plugs...to no avail.
    A fair amount of euros.....
    Oct 25 2008
    MD
    Quote Originally Posted by Low Flyer View Post
    Well the dealership did find the issue after doing a running compression test. My catalytic converter was starting to come apart. They replaced it and I have been driving the car for a couple of days, seems like the problem was sorted.
    Sep 01 2016
    Sacramento, Ca
    Interesting... how many miles do you have? What stage is your car?
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    i had this happen, especially at WOT - both cats were bad
    Junior Member Two Rings rey_reysA7's Avatar
    Sep 21 2018
    '84 VW GTi
    CO
    Hm wow. I am having this now. But it started the day I changed my spark plugs. It cuts out under hard acceleration, not just WOT but say 3/4 or more. Also when it is heat soaked it shudders the hole time. I put octane booster in it and it helped a lot, still there but not as much. I'm in the middle of a drive from Orlando to Ft Leonard Wood MO. So suck up 3.0"T"
    Sent from my G8142 using Audizine mobile app
    Current Cars 2012 Audi A7 1984 VW Rabbit GTI
    Sold Cars '78 Rabbit '87 Scirocco '99.5 Jetta 2.0 '00 Jetta VR6
    Established Member Two Rings i8snitches's Avatar
    Mar 03 2018
    2018%20Audi%20S5
    GA
    I had this a few weeks back when looking to perform some preventative maintenance when I discussed sparkplug options with APR. APR stated, "stage 2 cars we recommend NGK BKR8EIX gaped to .024"". Jumped on the internet purchased sparkplugs and new coilpacks for good measure. However after two weeks, while on the way to a car event, engine began to stutter/shake. Immediately pulled over to side of road and shutdown engine. I checked for codes with my ODB11 and no fault codes but did see warning on engine.
    Towed to my local indy same day -- even-though I was able to drive back home 20miles without issue didn't want to risk any further damage. My local indy shop stated codes were showing misfire on all cylinders... a look at the sparkplugs showed they were burnt. Replaced spark-plugs and so far been driving two weeks with no issue... did a few launches recently and no re-occurrence.
    I am still trying to determine why the sparkplugs APR recommended with Stage 2 (DP) would burn up with less than 30-days.
    2014 A6 3.0T
    MODs: APR Ultracharger & DP (57.75mm/187mm) | Roceuro CAI for APR Ultracharger| AWE Touring Exhaust with resonated downpipe | APR CPS | Eurocode Test Pipe | Bilstein B8 Strut | H&R Sport Springs | 036 Control Arm Kit | Eurocode Sway Bar Kit and Endlinks | Jokerz Ported Blower
    UPCOMING: Custom TCU tune
    Sep 01 2016
    Sacramento, Ca
    Quote Originally Posted by rey_reysA7 View Post
    I had almost this exact scenario on my 2.0t a4 after replacing spark plugs, turned out one of the new plugs was defective.
    Sep 21 2018
    '84 VW GTi
    CO
    Quote Originally Posted by i8snitches View Post
    Did you replace them again since this?
    Sent from my LG-V400 using Audizine mobile app
