Originally Posted by
tspesh
Firstly thanks for the replies. Next, I feel like a bad parent so I'll do my best to answer this stuff honestly.
1. The electric noise has to be the fuel pump then. I didn't realize opening the door would wake that thing up. I'll try and get a recording of it.
2. Bad Father Moment: I'm not sure the filter has ever been done under my ownership.
3. I'm not sure how to measure that, if the sound I'm hearing is in fact the fuel pump then I'm not sure how long it takes to prime is relevant because the noise is one of electric death. Instead of a small whine like you'd expect from a fuel pump it's more like a clickity clackity stutter. Think how a bad starter sounds as the servo is clicking, except much quieter. Thing is, the car starts beautifully every-time.
4. Re: throttle body -- fair enough
5. Rough idle...i'll grab a video of it. It's a drop in revs/power, momentarily. The high-rev upon start and then dropping down to 800...that much I've seen over the years to realize it's normal. This is not that. It's not a matter of the car shaking or anything like that so the motor-mount angle probably isn't what we're talking. It's more like the car want's to stall, but the revs never drop low enough for that to happen. And again, when it's doing it...it makes for a pretty "not smooth" drive.
The weird thing to all of this is that it isn't consistent. I just drove across town and conditions were perfect to replicate it: It hadn't been running for a while (last night), it's hot out, and it's been baking in the sun. Ordinarily this is when it would be the most severe, but today it ran fine.
Awesome response thanks for reading it all makes it much easier
One last thing, cam follower, whens it been replaced? If it hasn't... not good... It could be worn through which would mean the intake cam is worn along with the HPFP which could give similar symptoms and its not cheap to deal with
When the fuel pump is priming, its a sort of whirr sound. I meant timing it by counting (one second two seconds etc.) I only ask as my A4 has 40k and my mothers has 140k so I have a comparison, shes getting low fuel pressure codes intermittently and has a weird stumble when it starts sometimes (intermittently) does the acceleration thing etc. Her fuel pump runs for about 5 seconds every time, mine runs for a half second every time no matter how long its sat. I believe its her fuel pump causing the issues (or camshaft but with the way the pump is priming we are starting to point to that) as we've already replaced her HPFP and the low pressure sensor and it didn't help. BUT her cam follower was not worn through nor ever has been, thats why I suggest checking it if you never have and maaaybe be prepared to find ugly things (not guaranteed but very possible)
No check engine codes besides the misfires correct?
Also if you had those oil leaks like that, have you replaced the PCV? normally when you get the oil leaks from the valve cover it means the PCV is bad and is blowing out the seals. I'm not positive but I've heard it can create some weird issues which the turbo building up pressure in the crank case and causing odd things to happen (and blowing out every seal in the engine)
As a last thing that I just thought of/recalled. These cars have BAD carbon build up issues because of it being a direct injection engine (no gas washes over the intake valves so all the oil from the pcv builds up on it) I would suggest reading up on it (in the tech section or just search) but thinking about your symptoms, if you have no CEL, I'm thinking your due for a carbon cleaning. The intake manifold has to be pulled off, and the intake valves are either soaked in a chemical and scrubbed which can be done at home (takes hours and hours) or you pay an indy/dealer to do a walnut blast which is about 300-600$ and is done in a couple hours.
The carbon eventually builds up enough causing issues with the intake valves closing properly causing rough idle and stutter at low rpm's.
I'm not sure how mechanical you are in dealing with cars as that would also help in suggestions of you to pull things off or find a good mechanic etc
I would read up on A. Cam follower, B. PCV, C. Carbon buildup. (and do the fuel filter) and try to get us a video of the noises your referring to, its very hard to diagnose without seeing the car lol
Ps, the fuel pump IS pretty loud even in good shape, shouldn't be clicking though
PSS Sorry its so long lol
