Results 1 to 17 of 17
    Apr 09 2013
    Great White North
    My car sat for a month now the engine cuts out, stalls.
    My car was sitting in the garage for a month while I was on vacation, ran fine before that.
    I went to run some errands this morning and the car started fine but went about 25 meters out of my driveway before running rough, bucking and then stalling. I had it out yesterday for the first time and the only issue I noticed was an abrupt and momentary cut out while accelerating hard.
    I just did a vagcom scan and this is what I got:
    4 Faults Found:
    17887 - Brake Boost Vacuum System
    P1479 - 008 - Mechanical Failure - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 -
    16687 - Cylinder 3
    P0303 - 008 - Misfire Detected
    16688 - Cylinder 4
    P0304 - 008 - Misfire Detected
    Readiness: 0000 0000
    The car was idling when I did the vagcom and the engine just shut off in the middle of the scan. Starts right up again but won't accept any pedal input when in drive.
    I have 190000km on it. Fuel filter and NGK 11mm Iridium plugs and new Red-top coils were done at 150000km
    I can hear the fuel pump run when I cycle the ignition switch. Presently at 1/2 tank.
    MAF and air filter was replaced 2 months ago with a noticeable improvement in throttle response.
    I have the car back in garage and on a battery charger (just in case).
    Any flow chart/troubleshooting tips would be appreciated.
    Darren
    2004 Dolphin Grey A4 1.8TQA, Motoza Stage1+
    Apr 17 2016
    kc
    My bet is a vaccum leak. Lines, check valves maybe even the SJP.
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    Looks like you might have a vacuum leak at the brake booster, if bad enough it could cause the misfires.
    I would visually check the plastic rubber joint right before the vac line goes through the firewall to the brake booster as well as all the other lines, then do a boost leak test if you can't find anything suspect.
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Was it parked outside? If so check for a mouse nest in your air filter box or other rodent damage.
    Edit: Read it was parked inside. Still worth a peek.
    Apr 09 2013
    Great White North
    After work I'll head to the hardware store to get the items I need to make a boost leak test apparatus. I'll report back.
    Apr 07 2011
    Suction jet pump
    Apr 09 2013
    Great White North
    Thanks for the suggestions, the SJP is intact, and I see no obvious breaks or splits in the vacuum system. I replaced the SJP this past January when it split on me.
    I just restarted the car, it idles smoothly until I put it in drive then starts to shake and cut out. I picked up the boost tester parts, and I am trying to cobble together a fuel pressure tester I had laying around. The car has run well the last 3 years I have had it, sadly I haven't put much effort into learning any troubleshooting for it's common areas. I'll try to read up more tonight during the Olympics.
    May 22 2012
    FAIRBANKS/AK/USA
    Have you removed the old gasoline and replaced it with new?
    Stabil or Seafoam?
    2002 A4 3.0 MT
    Apr 07 2011
    Here's some more info on the first code.
    17887/ P1479/005241 - Brake Boost Vacuum System: Mechanical Failure
    Possible Causes
    Fuse(s) faulty
    if the blade wheel (rotor) in the vacuum pump is stuck, most probably a fuse will burn
    Hoses from/to Brake Boost Vacuum Pump faulty
    Possible Solutions
    Check / replace fuses
    check if the blade wheel (rotor) of the vacuum pump is stuck, otherwise the fuse will burn again
    Check Hoses from/to Brake Boost Vacuum Pump
    Check Brake Boost Vacuum Pump
    check if blade wheel (rotor) is stuck
    Perform Output Test
    Perform Short Trip in Basic Settings. Group 008 is commonly the self test for this system and may be activated Key On, Engine Off. If needed activate basic settings using [On/Off/Next] and pump the brake pedal.
    Special Notes
    When this fault is stored in conjunction with misfire and system lean fault codes check the PCV system and any other possible sources of engine mechanical vacuum leaks. Although PCV failure is most common on the 1.8T engines equipped with the auxiliary vacuum pump, any engine with low vacuum can cause that electric pump to run excessively - resulting in this fault code.
    http://wiki.ross-tech.com/wiki/index...7/P1479/005241
    Apr 22 2012
    Fremont, CA
    the fact it bogs down when in D till it almost cuts out says to me vac leak, I'm sure the boost leak test will show you what failed.
    Apr 09 2013
    Great White North
    Well, the boost leak test showed major air leakage at #2 and #3 fuel injectors. I hit everything on the engine with soap solution and there was major bubbles that appear to be coming from the injector o-ring seats. So to me, either the o-rings are failing or the seats themselves are. These are the Ford Motorsports injectors. Does anyone know if perhaps new o-rings can be ordered separately?
    BTW, if someone has a good how-to for seat replacement in their favourites I would appreciate the link.
    Nov 24 2014
    DMV
    Yes, you can order them from ECS. I believe they're a few cents (under a dollar) per o-ring, you'll need two per injector. I've been planning on doing this myself as preventative maintenance.
    If you end up needing new injectors check out the classifieds section. I've seen them go for super cheap on here. You may be able to get upgraded ones as well for less than the cost of new. Good luck!
    02 B6 A4 3.0 6MT Sport Package | Kenwood DDX9702S Double Din | Tint | B7 S4 Front Calipers & 345mm Brembo Rotors + Pads | Blauparts "U-Slot" Slotted Rear Rotors + Pads | ECS SS Brake Lines | APR Snub Mount | ECS Short Shifter | BFI Shift Knob | 034 Front Swaybar Endlinks | Lemforder RS4 Outer Tie Rods | SPC Adjustable Front Control Arms | Meyle HD Lower Control Arms
    Apr 09 2013
    Great White North
    OK thanks. I just pulled the injectors, #2 & #3 seats have a large vertical crack where the o-ring is supposed to seal. Looks like I'll have to take care of that first and see if that's the actual problem.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by DJMurphy View Post
    Fixing the injector seat leaks is definately something you should do but I doubt it is going to cure your reported problems. Injector seat leaks aren't going to cause the engine to stall and cut out while driving.
    Apr 09 2013
    Great White North
    OK, should I start with the basics then? New plugs, fresh fuel?
    I still need to do a fuel pressure test, just wasn't able to adapt my gauge to the hose with what I had lying around. I'll try a hydraulic store tomorrow to get sorted.
    Dec 28 2006
    Western Maryland
    Fuel doesn't go bad in one month. Definitely want to check your fuel pressure at the fuel rail. ECS Tuning has an inexpensive in-line option. Clicky click®.
    Apr 09 2013
    Great White North
    I should close this thread out.
    After I verified the correct fuel pressure I ended up throwing new plugs and coil packs on. No issues have returned since then, engine is running good so far.
