I flushed the brakes last weekend, and afterwards, during the week the brakes locked on. I scanned and it came up with the brake pressure sensor and/or brake switch being the likely candidate for the codes. I have a new sensor, but while I was waiting for that I decided to re-flush the brakes. Starting at the rear-left (furtherest from the reservoir), I couldn't get any fluid out of the caliper when pumping the brake with the nipple on or off.
After some further investigation, I removed the rear-left connection to the ABS line and fluid is getting that far. I tired an output test on the ABS and worked without issue. There is also no fluid coming from the brake line when removed leaving me to believe that the line is blocked. How does one go about unblocking this. BTW, the rear right brake flushes as per normal.
Any help would be appreciated.
