Results 1 to 11 of 11
    Established Member Two Rings B8ta's Avatar
    Dec 08 2009
    Houston, TX
    VCDS Air suspension mod on 2017 Audi Q7
    So today with the new VCDS update (16.8), I attempted to change the suspension height in 17 Q7.....it ended in disaster until I figured out how to recalibrate back to reference level. I raised the overall height by 10 mm. Not much but it still worked. Im happy I did this with zero instructions other than my past experience with C7.5 Audi S7 that was my wife's car. Now i need to figure out how to get lower. Anyone here have any thoughts on what I can do to change the heights again?
    Before:
    After:
    You probably cannot tell much, but I measured the fender to the ground it it was 10 mm taller in the Auto position.
    Work in progress, but its nice to have gotten it done and look forward to actually lowering it some and adding some nice wheels.
    2017 Audi Q7
    2017 Audi A4
    2013 Audi S6
    Veteran Member Three Rings Alipor's Avatar
    17 Q7, 04 Allroad 6-speed
    Upstate NY
    I would have assumed it was the same procedure as the S7/S6/A8, from what I have read on the S7 it is with mixed results that people were able to get them to lower. But reading yours, you got it to go up, shouldn't you just adjust the values and it should lower?
    Present:
    17 Q7
    04 Allroad Stage 3+ EPL Tuned
    Gone:
    09 TTS EPL- 04 S4 GIAC - 02 A4 APR 2+
    Registered User Two Rings
    Apr 26 2016
    Houston, TX
    It is a completely different procedure. The c7 platform uses module "Level Control" this uses module 77 "Adaptive Suspension" some of the menu features are the same but a lot, we have noticed, are completely different.
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    I know its an old thread but any update on this? Looking to get my wife a q7 with air and lowered my S7 with Vag and would like to do the same with the Q.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Jun 04 2014
    Santander, Spain
    Very interested in any progress in this also!
    Jun 04 2014
    Santander, Spain
    Quote Originally Posted by Aadel@EL1TE View Post
    But you've figuered out how to lower the air suspension? I ask because i'm interested in doing so, on mine.
    Thanks in advance
    Established Member Two Rings dasaint's Avatar
    Apr 05 2009
    Fife WA
    I would like to know if it is possible to lower the front of the car with ther rear during load mode
    2017 Q7 Prestige
    2009 Cobalt SS/TC ~400 whp (Friday and weekend racecarrr)
    2001.5 B5 S4 Tip Stage 2 (sold)
    2000 Oldsmobile Alero S/C 196 whp (Big junkyard in the sky)
    Sep 01 2018
    Norway
    Quote Originally Posted by apertura View Post
    Thanks in advance
    Can someone tell me how to lower a q7 2017 using VCDS?
    Sep 01 2018
    Norway
    Please tell me how I can lower a q7 using VCDS
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    I believe it takes a dealership tool to adjust the air ride height. There are also lowering links, which are probably the better choice.
    Sep 01 2018
    Norway
    i heard that its possible lower it in VCDS. They change the basic height setting of all wheels.
    I dont know how, but I would like to:)
