Results 1 to 33 of 33
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    My car is burning some oil!
    So right before my first service (5,000 miles) I got a low oil light. I was about 1.5 quarts low. I didn't really think much of it as I knew it was the break in oil. So fast forward to right now, (7,500 miles) my engine oil level is about halfway on the display so Im guessing I am burning a little over a quart every 5k miles. I do drive my car hard 95% of the time and it has been hot out so I am not overly freaked out about it but wanted to see if anyone has experienced some oil consumption in their cars?
    Before I got the S7 I was going to get a BMW Gran Coupe and was reading up on the forums and many owners were reporting massive oil consumption. I think BMW says 1 quart per 1,000 miles is within their threshold of normalcy!!! That just seems ridiculous so I am nowhere near that but haven't seen anyone post about oil consumption with the 4.0T so not sure why mine is burning some.
    Let me know,
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    had that issue twice on my A6 (during the 2.5 years ownership)
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Established Member Two Rings ekpyr's Avatar
    Jul 16 2007
    Long Beach, CA
    Quote Originally Posted by Djpeaksd View Post
    Let me know,
    I'm curious what other S7/RS7 owners experience.
    I drive a RS7 and I've consistently burned through at least 1 quart every 5,000 miles; usually earlier. I'm at 15,000 miles now, so I've added 3 quarts over that time. I drive in S mode 95% of the time and often upshift manually in 2nd/3rd at low speeds.
    I now carry a quart of oil around with me in case I need to refill on the road.
    Mar 14 2016
    Cleveland, OH
    I burn 0 oil in my 2016 S6. The break in process was pretty much the moto man method or aka drive it like you stole it. Have avout 6500 miles on my car now no issues previous to the first service and no issues after my first service.
    I think your oil consumption sounds excessive.
    No leaks?
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by ekpyr View Post
    Just found this little tid bit in the manual. "Depending on the way the vehicle is driven and the operating conditions, oil consumption can be up to 1/2 quart per 600 miles" Wow!!!
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Clipse3GT View Post
    No leaks?
    No leaks whatsoever! I did the same break in process as you!
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Mines the same as your DJ. Burns about a quart between oil changes. Which I still do every 5000 miles or so.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Jul 16 2007
    Long Beach, CA
    And there we have it. Thanks for sharing.
    Mar 14 2016
    Cleveland, OH
    Do you idle or warm up the car excessively? Lots of stop and go traffic?
    Mar 29 2014
    Hampshire, UK
    Just had my 15k service. (Well 13,750 to be exact)
    Prior to this I had the low oil level indicator once, and put 2 quarts in - this was around 9k, then I had a further quart at 12k. So its definitely using some oil. Im not tracking or driving hard either, just normal daily motoring, with a mix of highway and urban roads,
    No visible oil leaks and exhaust is clean.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Feb 01 2016
    Encinitas, CA
    I would be really bummed if I burned that much oil though! Seems like a bailout for Audi!!!
    Nope, 1 mile commute to work and very little traffic on freeways when I'm on them.
    Quote Originally Posted by jkwelsh View Post
    Good to know that I'm not alone on this!!!
    Jan 15 2013
    2013 Audi S7, 2012 Land Rover LR4 HSE
    I've only had to add oil once in 30k miles and that was shortly after my stage 3 install. That being said, I never went the full mileage between oil changes. My R8 on the other hand needs a quart of oil between oil changes, every 4-5k miles or so. This was the same pre and post twin turbos.
    Really think it depends on the car/motor and how you drive it. I don't worry too much about it, just keep an extra quart in the trunk as it's not exactly easy to find Audi/VW spec oil in a pinch.
    2011 Audi R8 Spyder - Ibis, 6MT, HRE P43S, white calipers, gloss black vents/trim/window frame, tints/radar/laser, UGR TT
    2013 Audi S7 - Estoril Blue, RS7 carbon diffuser, skirts, mirrors, tint/radar/laser, Eurocode sways & links, APR Stage 3 (RS7 turbo & intake, APR downpipes & AMS boost cooler), 285/35/20 on 20x10 ET25 ...GONE
    2017 Audi Q7 - Graphite Gray, BOP
    2001 Honda S2000 - Silverstone Metallic
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    My 2016 S6 went 16,000km (before the first service), without needing any oil. I also broke it in by driving it hard and taking it to redline often.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Mar 14 2016
    Cleveland, OH
    Might be the problem if you commute only 1 mile each way to work. Nothing gets to operating temp. So you get plenty of oil blowby on your oil piston rings.
    May 30 2016
    Lake Forest, CA
    I wonder if there is a good oil catch can for these cars. I'd love to get one for mine.
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    i think apr has a universal can we can use
    Veteran Member Three Rings amelen's Avatar
    Nov 08 2014
    North NJ
    Interesting. I just had my 15k mi service (11mo and 10k mi since the last service). Neither time did I have any issues with low oil.
    - Alex Melen | Facebook | Twitter | LinkedIn
    2016 Audi S6. Sepang Blue w/ Lunar Silver and Layered Aluminum/Black Wood / Prestige / Black Optics / Sports.
    Past: 2015 Porsche Macan S | 2012 Audi A7.
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    Quote Originally Posted by MadAboutCars View Post
    What he said. In 55k miles I was always a quart down between changes. I went 15k between changes and I had audicare to 45k. I never babied it ever. But then I traded it in for a 2016 and I expect to treat it the same. IMHO, the break in stuff is over rated. Maybe back in the early days it made a diff...today's metallurgy is so much more tolerant.
    2016 S6 Mythos Black Metallic, B&O Sound, Sport Package, Driver Assistance, Comfort Seating, Black Optics, Audi Exclusive Interior.
    My wife said its golf or her, gosh I'll miss her!!
    Sep 19 2014
    Newcastle
    It's standard I think mate mine loves oil the S4 was the same. Dont worry about it
    Sent from my XT1580 using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    exactly what i was thinking. If you drive it in S and hard 95% of the time as you state this could be the issue. Nothing wrong with driving the car hard, i do it to mine every single day, but only after the oil is up to full operating temp. Until then i never go above 3000 RPM's.
    B6 S4 Cab - Sold
    B7 S4 - Sold, (sadly sold, this was my favorite)
    C6 A6 3.0T - Sold
    B8 S4 - Sold
    2015 SQ5 - Sold
    C7 A6 3.0T - Sold
    2016 SQ5 - Sold
    C7 S6 - Sold
    B9 A5 Sportback - Sold
    C7.5 S6 - Current
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Black3.2 View Post
    So I do let my car fully warm up before I get on it for sure! Even when the rpm lights go away I always check my lap timer to make sure I'm at least at 190 degrees. Which is pretty easy as I get coffee every morning at my drive through place and its right across the street from my house but it does give my car some time to warm up.
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    This is fairly standard for modern forced induction cars that see high cylinder pressures (blow by) with EGR systems that recycle the vaporized oil gases back into the intake system to literally be burned off. As pointed out, this blow by is more prevalent on a cool motor (laws of thermal growth) as things seat better once the engine is thermally stable at operating temps. It's dependent on your driving style as more throttle means more pressure, more of the time.
    Do it right, or don't bother.
    Nov 29 2015
    philadelphia
    So I'm
    Going to piggy back off of this. Three times now I have been burning oil to the extreme. All three times I've had to
    Top off under 1000 miles in between. I am again less than 1000 miles from last top off and I am right above the minimum line. Not to mention I'm only getting roughly 12-13 mpg on gas, and this is an A7... Any thoughts on what the heck is going on? And yes I do drive hard 99.9% of the time..
    Sep 19 2005
    Milwaukee, WI USA
    Ken,
    That seems excessive. I usually get a low level warning (about a 1-1.5 qts low) right around 5000-6000 miles in with my 3.0T. That is typically right around where to do my own full synthetic oil changes. If the warning light comes on first, I'll just do it then. I also have a long term fuel average of ~23mpg. That said, I don't always drive aggressively. I do usually hit WOT a little bit eaxch day at some point though. I'm no slouch on the road but usually pacing along just quick enough to be in front of the pack.
    Your case sounds more extreme.
    Feb 01 2016
    Encinitas, CA
    I think you guys may be right! I noticed my driving behavior this morning and looked at my temp when I would normally get on it and even though my redline went up to 6,500 I did notice the temperature through the lap timer was only 155 degrees so I am guessing this could have been contributing to some of my oil consumption. What is full operating temp, 190 degrees and above?
    Sep 23 2010
    NNJ
    I had this problem in by B8 A5 and Audi finally acknowledged it with a class action lawsuit. I was putting in 1Q every 1000-1200 miles.
    After running oil consumption tests and all, Audi ended up replacing the pistons. Pretty much a full rebuild of the engine.
    Just recently got rid of the A5 for a RS7 so no complaints so far
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Quote Originally Posted by kenphilly View Post
    So I'm
    Pcv is shot, if you're burning that much oil from blow by your engine is sick
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Dec 14 2011
    Dublin, OH
    Quote Originally Posted by DGVR6 View Post
    If this is true are there other symptoms that would indicate the PCV is not working properly?
    Aug 03 2014
    Queens
    Try the oil cap test.. If you can't get it off while the engine is running, it's bad.
    Previous
    Dec 14 2011
    Dublin, OH
    Ok. So I tried the oil cap test. I can get it off but it's very hard and you can hear the suction sound, where its vacuum sucking like crazy. Is this normal or should I get it checked. I asked the guys when they did the stage 3 build if they noticed anything abnormal that might contribute to burning oil. They claim they noticed no oil dripping or anything. I'm about 2200 miles in since my last oil change and my gauge is about a quarter way down from the top.
    Aug 03 2014
    Queens
    There's supposed to be some vacuum, but fairly easy to remove regardless. If you've removed it once before, you'll know the difference.
    Post a video up if you're not sure and see if someone can compare.
    Previous
    Dec 14 2011
    Dublin, OH
    Quote Originally Posted by Dguth View Post
    Can someone else post with yours, how hard is it to get off. As posted above, mine is suctioned on pretty tight. You can remove it but you have to pull pretty hard and you can hear the vacuum/suction sound.
    Dec 14 2011
    Dublin, OH
    Hey guys. Bumping this question back to the top. I'm trying to figure out if my PCV is working properly. Can someone check on your S6 or S7 how hard it is to pull off the oil cap while the engine is running? Mine is very difficult as there is a lot of suction pressure.
