Results 1 to 27 of 27
    Established Member Two Rings Cobra351's Avatar
    Feb 22 2013
    NY\C
    Question New owner questions
    So I've just purchased a '06 A4 Quattro with 130k, coming from the previous gen(e46) BMW. So far, I'm loving it. Anyhow, the car needs a few things. Timing belt component kit, shocks\struts all around, and front upper control arms(don't know if the bottom ones are good or not). My questions are:
    1) what site do you guys recommend to get OEM\OES parts for these cars, besides ECS tuning and FCP Euro?
    2) is it okay to buy any of these front complete upper and lower control arm kits?
    https://www.fcpeuro.com/Audi-parts/A...54&m=20&page=1
    3) what timing belt component kit(and from what site?) is the best? I know i'll definitely be getting a water pump with a metal impeller only. Any help would be appreciated. Thanks!
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Europaparts since you are local to them.
    They have a great TB kit. FCPeuro is a good option.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Jun 17 2013
    jersey city nj
    If your order from Europaparts you will likely get it next day or even same day
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    German auto parts offers decently priced OEM stuff.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by seandon_792 View Post
    I use them for my MK1 GTI parts. They also ship . I usually get stuff from them next day Since they are located in up state NY
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    rockauto.com
    Senior Member Two Rings OliNix's Avatar
    Oct 22 2014
    London, UK
    Meyle HD kits are good for control arms, I wouldn't buy cheap ones (febi, blistein) you will just be doing them again in 10k miles!
    Cheers,
    Oli
    May 20 2014
    e92
    Just letting you know since you came from E46, DIY on B7 are much more involved than in E46. I own(ed) E46 and B7 together and E46 was much easier to work on. E90/E92 is same too.
    But timing belt DIY is so much more easier than in other cars, I think I went with europaparts kit last year on my 05.5 B7.
    Feb 22 2013
    NY\C
    Thanks for info gents.
    Quote Originally Posted by OliNix View Post
    Cheers,
    Oli
    I thought Bilstein and Febi were decent since they're German, but ah well. I bought the Meyle HD's, and they're going for a great price on FCP Euro in case anyone is wondering- $336 for the entire front; upper & lower, and tie rod ends.
    Is this Bilstein shock absorber kit OEM\OEM ride quality?
    Quote Originally Posted by trj View Post
    Thanks for the info. Luckily I have 2 friends, 1 of which is an Audi\VW master tech. I gathered as much about working on it, it's a completely different design. I'm looking forward to no cooling problems(plastic expansion tank cracking, sh!tty clutch fan, sub-frame crack worries) like with my experience on my e46. My only worry is that I've got the diesel-like tapping sound coming from the engine, when warm and under 2000 RPM. I'll be replacing the cam follower along with the hpfp o-ring and mounting bolts and PCV valve. I just hope that quiets it down, and that there's no issues with the timing chain\tensioner.
    The car also once in awhile throws a P0442 code(evap emission system leak detected- small leak). I erase it and it'll go away for some time, then come back after a few days. I'll be replacing the gas cap first also. Any idea what it could be? Thanks again everyone.
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Quote Originally Posted by Cobra351 View Post
    I had that code on my B7 sedan and for me it turned out to be the charcoal canister down under the rear of the car. I also had the symptom of not being able to put more than a few gallons in the tank without the nozzle clicking off. Thanks for the heads-up on the FCP kit. I used their products on the sedan but now the Yeti is looking to need that attention as well...
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Apr 24 2016
    California
    Quote Originally Posted by papadelogan View Post
    I don’t have a code but also have the problem of gas pumps clicking off. Real pain to fill her up because I have to hold the pump at halfway and even then depending on the pump design it’ll still click off. You’re saying the charcoal canister fixed this problem? How the heck does that affect the pump auto shut off?
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by RakkCity View Post
    The charcoal canister acts as a vent and has a adverse affect on the internal psi within the tank when up
    Apr 24 2016
    California
    Good to know, how much for a new canister and is it an easy swap?
    Jun 17 2013
    jersey city nj
    Couldnt tell yaa. I never had to it on the A4. I replace it on my MK1 GTI. I could tell you the price on that 1 if you like....lol
    Apr 24 2016
    California
    Quote Originally Posted by vce1232000 View Post
    Ah oops, thought you were the one I’d replied to. Found a DIY here http://www.audizine.com/forum/showth...ng-Gas-Problem
    Looks like the part is about $170 from ECS but theres a few car part outs going on right now
    Jun 17 2013
    jersey city nj
    aluthman has a out going as we type. Pm him. Pretty sure he'll sell it reasonable $$$$
    Jul 31 2011
    I found a used one from a wrecked car with 40k miles. Don't remember the cost, but the swap was easy.
    Sent from my HTC One M9 using Tapatalk
    Feb 22 2013
    NY\C
    Thanks for the info, I just had the filling up gas issue just a few days before you mentioned it. I thought maybe it was the gas stations pump. Fuel clicked off, and I thought my tank was full, when in actuality it was only 3\4 full.
    Have any of you had timing chain\tensioner problems? I'm hoping that the loud "diesel like" sound coming from the engine is only the cam follower, and not chain rattle. Only time you can hear it is when car is reaching operating temperature, and above 2000 RPMs.
    Jul 31 2011
    I did not have timing chain/tensioner issues but then... my timing belt broke on me @ 140k miles so I replaced all that when I fixed that issue. People claim this "diesel like" sounding issue but I don't hear it, probably because I have a real diesel, a 1999 F250... so for me, my 2.0T is super quiet.
    Jun 18 2015
    DavidhogAJ
    Philippines
    So yes, excellent deal on the Meyle kit, good find there... since no one answered it yet, that strut kit is an upgraded "Sport" line, B8 Bilstein series, not to be confused with Audi B8. The OEM ride quality would be the B4 series, which doesn't appear to be offered on FCP Euro, I got a pair for the front off of Rock Auto pretty cheap... Also, since no one brought this up, I used to have another car with Direct Injection, they are definitely noisier as far as what sounds like upper engine noise like you are describing, I'm guessing that could be what you are experiencing as I hear it on my B7 (with recent cam job) and on my '13 Focus that has DI as well.
    Mar 24 2013
    Oakdale, CT
    My FCP control arms lasted for about 40k miles with no issues. They were still fine when the car was totaled. If someone says they only lasted 10k or less miles, they were installed improperly or they had other serious alignment issues.
    -Adam
    Oct 22 2014
    London, UK
    People often get Febi Bilstein and Bilstein mixed up. They are completely different companies with different levels of quality.
    I would buy Bilstein shocks all day long, they aren't cheap though:
    http://www.bilstein.com/
    However Febi Bilstein pattern parts I wouldn't touch with a barge pole! They are part of the bilstein group:
    http://www.bilsteingroup.com/
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    If they are part of the same group aren't they just a cheaper alternative?
    The noise is more than likely the hpfp firing (injecting) unless ots really bad then idk lol but my mothers b7 is way louder than mine (with the diesel sound)
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Oct 22 2014
    London, UK
    It's a different group, conveniently named the same!
    Jul 25 2016
    new hampshire
    ohhhhhhh
    Eric
    Feb 22 2013
    NY\C
    Thanks, will be doing that. It's fvcking annoying not being able to pump gas without interruption, and the CEL coming on every few days.
    Hah, I bet it is quiet compared to a F250. I've heard some people say the tapping noise is normal, others say it went away after changing the cam follower, and some of course saying it's the hpfp. In any case, I will post a before and after video of when I change the cam sensor this weekend.
    Quote Originally Posted by danbfree View Post
    Thanks for the info. I ended up buying this Bilstein non-sport kit:
    https://www.fcpeuro.com/products/aud...n-b7bilsteinoe
    Good to hear, also notice you're in CT. How are your roads? You know how NYC roads are, I'll try my best to dodge the craters, and that's why I got the Meyle's.
    Jun 18 2015
    DavidhogAJ
    Philippines
    From the description it still looks like the B8 series, but that should be fine, I doubt that they are too "harsh"
