Results 1 to 4 of 4
Thread: AC Issue
    Oct 16 2013
    nj
    AC Issue
    I've had this issue for a couple of years now with the AC when I come to a stop for longer than 30 seconds. I'll feel the engine kind of shudder for a second and then immediately after the AC will stop blowing cold air. Once I start driving again, it will take 5-10 seconds for it to start blowing cold air again.
    I went to the dealer years ago about weak AC, but I don't recall the engine ever shuddering like it does now. The techs said there was a leak in one of the lines so they replaced it and recharged the refrigerant. It was fine after that for some time.
    Has anyone else had a similar experience? I tried searching but came up short.
    Thanks.
    Nov 29 2015
    Vaughan/ON/Canada
    i have the same issue but i have not addressed it yet
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    I get the engine shudder but the a/c stays cool. I've noticed my boost/vacuum gauge reading bouncing all over when the shudder happens. Not sure what the cause is either. Very strsnge, I too thought maybe my refridgerent was low. Had it checked and even tho the level was fine still had it replaced. Made no change. Issue still stands. What your guys vacuum reading with the a/c on?? I notice the shudder happens when the car has a low vacuum reading. -10 when it should be -16 to -20
    Feb 02 2016
    Not sure if it's similar issue, but I just picked up my a4 for stage 2 oil repair and now ac only blow cold air when gassing. Since I'm out of warranty I don't know whats going to happen.
