Results 1 to 9 of 9
    Veteran Member Three Rings BLopes07's Avatar
    Nov 08 2009
    North Jersey
    Spare tire question-when moving to larger wheel spec
    I have a 2012 audi a4. going from the original s-line 18 inch wheels to 19 inch peelers.
    the car comes with the "donut" spare wheel of course. In case of a flat with the 19 inch peelers, can i use the original donut? Is the donut the same size for the 18inch and 19inch vehicles. Tried searching and couldn't find an answer. Has anyone used their stock donut when they upped their wheel size etc.
    thanks guys.
    [Audi 2006 A4 2.0T]-Revo Stage 2-custom borla exhaust-034 Silicon Turbo Inlet Hose-034 Test Pipe-Oem Piston Diverter-Carbonio-VMR Boost Gauge-v8 coils
    -Full S.Line Conversion-S4 Door Blades-Deval Lip-Oem Titanium Rims--H&R Coils-Titanium Grille-ECS Drilled and Slotted Rotars
    Sep 09 2010
    Destin, FL
    Did you even look at the spare tire for the size? If so you would have seen that it's a 19" donut perfect for those peelers...
    The donut is used for 17-19" wheels.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Quote Originally Posted by The Infiltrator View Post
    Not only this, but when you slapped those peelers on, did you account for the overall diameter of the tire by using a lower profile tire to accommodate the increased wheel size? The diameter of the wheel isn't all that important when talking about a spare, but the overall diameter of the tire should be roughly the same.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Quote Originally Posted by bakedziti View Post
    ^This. Also should be factored in for purposes of your speedometer.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    If all B8 Spares are the same, the rolling diameter is nearly identical to a 255/35/19 tire. I know from recent experience.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Nov 08 2009
    North Jersey
    im asking because its my girlfriends car. i haven't been able to check the spare size. so perfect, wasnt aware it was a 17-19 inch. that helps me out.
    i havent received the peelers yet, it was something i was curious about. my b7 i have a full size spare and my m3 unfortunately doesn't have a spare or donut. so as for her car i wanted to get more information on.
    the peelers are on a 255/35/19 tire.
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by BLopes07 View Post
    Then the rolling diameter is practically identical to the spare. Well within tolerances.
    Sep 09 2010
    Destin, FL
    This would have been great info in the already existing tire thread...
    http://www.audizine.com/forum/showth...ire-Thread-***
    Nov 08 2009
    North Jersey
    Quote Originally Posted by adamazing View Post
    perfect, i really appreciate it guys. i didnt have access to the spare so i thought id ask and you guys delivered.
