Results 1 to 3 of 3
    Senior Member Three Rings JJ.'s Avatar
    May 22 2012
    Netherlands
    V6 3.0 Camshaft timing - open circuit
    Hey guys,
    This problem just occured:
    Camshaft timing adj. Bank2 (n208)
    P1536 - 004 - Open circuit
    I just thought it was a bad sensor, but since I have a spare engine I swapped the sensors, after the first swap the problem was still there, swapped it for another one, still there.
    I can't figure out what to do now, must be something to do with the wiring im afraid?
    All the other camshaft sensors are oke, just this one throws a code.
    I have the check engine light on and the car slightly vibrates when running stationary.
    It's a FWD automatic 3.0 V6 cabriolet.
    Can anyone point me into the right direction? Im not very good with this electric stuff..
    -Cactus green Audi S4 B5 on air
    • Instagram: jj_dw
    • Instagram: jjwphotoworks
    Instagram: jj_dw
    May 22 2012
    Netherlands
    No one?
    • Instagram: jj_dw
    Instagram: jj_dw
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    Quote Originally Posted by JJ. View Post
    ... must be something to do with the wiring im afraid?
    I agree. That sensor wiring (below the coolant reservoir) gets a lot of heat from the catalytic converter below. As a next step, I suggest inspecting that wiring. The plastic tubing that it runs through is probably very brittle. Or gone.
