Originally Posted by
diagnosticator
I questioned why you removed the SAI because typically guys who do this don't really know why the SAI is installed in the first place, and do so because it seams to be the popular thing to do. I don't know what you know or don't know otherwise. Your questions imply an incomplete background regarding how and why the various engine systems function as they are designed, including the boost control system. I don't love the SAI so much, I don't consider important engine equipment optional, and usually the decision to remove SAI suggests guys doing this think they know more than the factory does about engines. If your are fully aware of the technical aspects of the SAI, and that something about the plumbing is mis-configured from removing SAI, why did you post here? No offense intended.
Im sorry i shouldn't have jumped right off the gun to assume you were being insulting. i apologize.
old guy
Since your underboost code appeared immediately after you modified "whatever" I have to assume something is hooked up incorrectly. You mentioned an SAE delete and that you blocked off the N249. My assumption is that you are referring to the SAI (secondary air injection) system. Not sure about the blocked N249. If you could provide a better description and/or a few pictures of what you changed I am sure we can figure out what went haywire.
So after carefully looking into the system, everything was hooked up correctly. i boost air tested the system checked fine, so i went ahead and smoke tested the system as well. it was also ok.
some history on the car, when i bought it the motor was blown. i did a complete rebuild on it, as well as completely going thought the suspension, as well as the interior. this car should have been taken to wrecking yard but i love fixing them and bring them back to life. this car runs amazing feels awesome. after the rebuild i didn't delete the vacuum lines/ SAI pump until i knew it was running ok. BUT i forgot i scanned the system before the delete and i had a under boost code, I'm can be away long periods of time for work so when i got back i completely forgot about it and did the delete.
with that being said i went ahead and put all the old vacuum stuff on it but since i went thought the trouble of putting it back on. theres no way I'm taking it off again, but i did get all new lines, check valves ..EXa... drove it still under boost. installed a boost gauge to see exactly what is going on I'm peaking at 6psi and holds. i went ahead and did another boost leak test.. nothing.. as well as a smoke test.. nothing. so with no leaks and all valves/ solenoids being new. theres only one thing left to try and that is a waist gate actuator test. tomorrow i will test the actuator to see when it begins to open. (the previous owner replaced the turbo with a new one) so I'm thinking the actuator just needs to be adjusted.
My question is, stock audi boost should be roughly like 10-12 psi correct?
