So after getting an alignment done at Firestone today, looked at my alignment print out and noticed it looked a bit off to me. After reading many posts concerning alignments and shifting the sub-frame to equalize the cross camber on the B6 I decided I'd need phone a friend on this one.
Taking many posts into consideration I did the following in preparation for the alignment:
Car is an 04' 1.8T USP with OE sport spring/shocks
DIY toe constant adjustment- all the way down to the notch
FCP full front control arm kit with TRE and hardware- bushes were shot on the oe arms
P/S rack pre-load adjust- loosened until knock was heard then tightened just enough to eliminate knocking sound
Talked with Firestone tech to custom set toe in- see align sheet
After the alignment the car drove much better with less noise in the cabin, significantly much less wander and tram-lining and the steering wheel wants to self-center now on it's own after making a turn. Before I would have to recenter the wheel after most turns. I even did the rack pre-load adjustment prior.
So the remaining issues I need you guy's help with are this...
I cannot find a caster spec anywhere in the Bentley- is there one? I am aware the lower control arms set the caster and it is not an adjustable angle.
Next, the camber on the driver side is at the max negative end of the spec but the passenger side is already past the negative spec by .4 a degree so shifting the sub-frame wouldn't bring this into tolerance but only make the driver side more negative and out of tolerance, unless I'm missing something?
Lastly, the car still drifts left. Now this I suspect is due to the camber. My guess is that since the side with the most positive camber is the left side and the right side tire is leaning more toward the opposite side inducing the left side drift.
Let me know what you guys think, I really wanna keep this car and get it all sorted. Without this site I don't think I would have made it this far. Well looking forward to your advice and thanks in advance.
Stay
